Resident Curmudgeon
![]() Join Date: Dec 1999
WTB - Th400 Inspection cover
I need an inspection cover for a TH400 transmission, including bolts/hardware. I think a TH350 cover will work too. Let me know price plus shipping cost to 03580
Thanks.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Member #1049
Re: WTB - Th400 Inspection cover
Jeff,
I have several at the shop, I will dig them out today, do a little degreasing and get you pics of the nicest one, how does $25 shipped sound? FYI.. T400 and T350 do use a different cover.. |
Resident Curmudgeon
Sold! Paypal okay?
Thanks Jeff
Resident Curmudgeon
Also, if you have it, I need the oil pressure fitting for the block and oil pressure line for a 72 402 BB
Member #1049
Jeff,
Here area couple of pics... Yes paypal works.. sorry I am not able to help you on the oil pressure fittings or lines.. PM sent... |
Resident Curmudgeon
Thanks Mark!
Mark, if you have another TH350, I could use one. Seems like my son needed it more than me
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Not to hijack just resurecting but do you happen to have another th400 cover Mark? Did away with my th350 in favor of the 400 and didn't feel like modifying my old one to fit. Thanks in advance
Member #1049
Jeff, You are most welcome!!
jaros44sr ..... I will look tomorrow at the shop and see if I have one for a T350. Do you need one for the large 168 tooth flywheel or one for a 153 tooth? (they are different, if your starter has bolt holes that are staggered its a 168 tooth) ssean .... I do have more but I will have to count my tranny's tomorrow and see if I have an extra one. Last edited by Livrat; 06-03-2009 at 08:55 PM. |
[QUOTE=Livrat;3342075]Jeff, You are most welcome!!
jaros44sr ..... I will look tomorrow at the shop and see if I have one for a T350. Do you need one for the large 168 tooth flywheel or one for a 153 tooth? (they are different, if your starter has bolt holes that are staggered its a 168 tooth) Good question, I don't know the answer to, by your description I will try to figure it out
Member #1049
this info will help you identify yours....
Large flywheels are 14" in diameter, and have 168 teeth on the starter ring gear. Starter noses used with large diameter flywheels have two offset bolt holes. Small diameter flywheels are 12-3/4" in diameter, and have starter ring gears with 153 teeth. Starters for small flywheels have two bolt holes which are paralleled to the back of the block. |
#12 | |
#13 |
Mark, are these the staggered bolts you are referring to
#14 |
Member #1049
Yes, that is the 168 tooth flywheel.. I do not have a good one left your application..
#15 |
Member #1049
#16 |
Hey, thanks for checking.
