2 piece driveshaft conversion to a 1?
on my 73 c10 with 454 bbc it originally came with the two piece driveshaft. since i lowered the rear im having problems with the pinion angle. it looks to me if i had a single driveshaft this problem would be eliminated. does this sound right? is it ok to put a single driveshaft with the th400 and 454? is the only thing i would have to do is remove the carrier bearing support and bolt in the new driveshaft?
resident wrencher
Re: 2 piece driveshaft conversion to a 1?
yea its fine i like the 1 peice better all you have to do is the carrier bering removal and you shuld be golden you migt still need to shim your rear end
will a driveshaft for a th350 fit in a th400 as far as splines go?
also will the length of the driveshaft for a th350 and a th400 be different assuming the differentials are the same
Does your trans currently have a "fixed yoke"? You have to have some "slip" in the system somewhere to take up suspension jounce and I think that currently takes place in the center support bearing.
Other than that you should be ok. The reason the factory had a two piece drive shaft in the first place is because they didn't want you to exceed the "prop shaft critical speed", that is, the drive shaft rpm at which it starts to bend and swing like a jump rope. Since that's a function of length and shaft rpm the two piece shaft takes care of the critical speed concern (trading it for an increase in cost, complexity and part count). As long as you choose or create the right shaft (material, diameter and rpm) it should not be an issue. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-02-2009 at 02:43 PM. |
I have car A.D.D.
Wow, what an explanation. Thank you Keith. I always wondered why we had those 2 piece shafts.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
Depending on how low you are, the driveline angles will always be tough with a one piece driveshaft.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
here are a few pictures so you guys can see the drastic angle of the driveshaft. this is three leafs on either side and thats the only modification. im going to add one leaf and see if that will correct this.
Gentleman Jim Driver
Why not just lower the carrier bearing?
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds |
i would need to raise the carrier bearing to fix the angle. im going to add one leaf back in tomorrow to see if it helps. i will post pictures
Cheyenne Super
I'd say don't raise it up, but it looks like you're ridin on the bumpstops anyway.
I don't think I've seen you're truck before, can you post some pics of it. |
just saw this .did you raise your carrier bearing
?did it help? |
#13 |
cheapest and easiest way to go........ is cut the original carrier bearing perch out and weld a flat plate in...... then bolt the bearing too it.(raising) it.i did this about 4-5 years ago and never had a problem.here's a pic of how it look's.
" Never look up a dead dogs butt."
#14 | |
Hope this helps. |
#15 |
I really hate wet sanding!
![]() Join Date: Dec 2008
No, the 400 has a much larger in diameter tailshaft!
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
| Bookmarks |
