Old 06-02-2009, 01:41 PM   #1
audittq225
just bought 65 gmc, couple ques
headlights work, but only when i pull the knob out all the way. all 4 come on, but not jus the low beams, only both.
also can someone tell me the wire setup on front turn signals?
audittq225 is offline   Reply With Quote
Old 06-02-2009, 01:55 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: just bought 65 gmc, couple ques
Did you try the dimmer switch?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-02-2009, 02:31 PM   #3
slepysal
slepysal's Avatar
Are the low beams good? Try checking them out by a direct conection . check the wire harness at the fire wall, and at the radiator support
Make sure your grounds are good and clean.
Trucks looking fine Joe
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 06-02-2009, 04:06 PM   #4
audittq225
the grounds have to be good if they come on when i pul the knob all the way out. right? there are four lights, 2 for low beam and two for hih beam, bubt from what ive gathered, all fou should come on in high beam. right? so that shuld say the lights are good, but the switch? also dimmer switch? i noticed the knob turns to make the dash lights brighter or not, is that what you mean? also tiny switch before the 3 knobs? any ideas?
Old 06-02-2009, 05:06 PM   #5
audittq225
i could be wrong the grounds might not be wired right? does ne one have a wiring diagram?
Old 06-02-2009, 05:40 PM   #6
jchav62
1962 C-10
jchav62's Avatar
The dimmer switch on the floor. Stomp on that and see if the two middle turn off.
Joseph Chavez
Old 06-02-2009, 06:40 PM   #7
1964C10
1964C10's Avatar
Joe, where did you get that wiring diagram? I have both the shop and assembly manuals but they are in black and white and not color.
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 06-02-2009, 09:21 PM   #8
audittq225
hey thanx i was wondering what that was, ill try it out. i was born 20 years after this truck, its my first classic.
Old 06-02-2009, 09:53 PM   #9
protrash64
Resistance is Futile
protrash64's Avatar
Im not an expert on the trucks with 4 eyes, but I thought only two headlites at a time were supposed to work????? Anyway, to the site and good luck.....lets see some pics. I get to be first on this one......................
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-03-2009, 09:43 AM   #10
jchav62
1962 C-10
jchav62's Avatar
I believe I got it from here on another thread...I think Sheriff joe231 posted it. I saw it said to myself, "that looks handy", then I saved it...
On quad headlight trucks, in low beam mode only the outer two are on, and all four in high beam mode. The outer two headlights have a low and a high beam circuit in them and the inner two are high beam only.
Joseph Chavez
Old 06-03-2009, 09:44 AM   #11
jchav62
1962 C-10
jchav62's Avatar
You will learn a lot here...
Joseph Chavez
Old 06-03-2009, 10:40 AM   #12
MacAttack
283 Drama Queen
MacAttack's Avatar
WELCOME to the forum.
You'll get all the information you need to make your rig operate right from these guys (and gals) and about a millennium's worth of combined experience.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 06-03-2009, 03:42 PM   #13
audittq225
well that def worked. good im glad it did. i knew i wired it right. story is guy was selling it on craigslist. he was gonna give it to his son when he turned 16. hes 14 now and started working on it a bit. well now his dad just decided to give him his truck instead. his dad wasnt supervising him when the kid was working on the truck and the kid cut the headlights off, he didnt they could be pulled off. so when i bought it i had to wire them back on. i just didnt know about the floor switch. thanx for that. i got everything else working, sounds like i might have a rod knock though. hopefully i can just tighten the rocker up a bit and itll be ok. ill get pics up too sooner or later, its rainy right now. plus im a photo freak and i like to take good pics. its not quite in pic takin quality yet, i just put a new bed ( plywood ) in her the other day, and sprayed some rubber coating on the walls of the bed.
Old 06-04-2009, 09:19 AM   #14
jchav62
1962 C-10
jchav62's Avatar
Cool! I'm glad...
These trucks are always photogenic. Snap some pics...
Joseph Chavez
Old 06-05-2009, 05:45 PM   #15
audittq225
another ques, so i had the headlights working for a couple das, but now, nothing. every other light works, except headlights, no low or high beam. whats wrong. the lights arent burnt out, the fuses under the steering wheel are good, and i tried replacing the light switch, is there someting else im missing? someother relay or fuse located somewhere else?
Old 06-05-2009, 05:57 PM   #16
audittq225
could it be the dimmer switch?
Old 06-05-2009, 06:27 PM   #17
audittq225
nvm it works now. believe it or not all i did was unpluged the dimmer switch and plugged it back in. it worked. looked a lil corroded. ill clean it up.
Old 06-05-2009, 07:17 PM   #18
protrash64
protrash64's Avatar
Bad connections are not uncommon on these trucks....they are getting a little old at this point. My core support connector was loose and it took me a while to find it; caused my lites not to work, too.
