06-02-2009, 05:13 PM | #1 |
Sway bar touching airbags -- help!
I just installed a front sway bar from Early Classic and when installed, the ends are up against the airbags. I double-checked the brackets and it looks like everything is in order. Anyone else had this problem and if so, how did you fix it?
On a side note, I took it around the block and the difference in handling is pretty pronounced.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
06-02-2009, 05:24 PM | #2 |
67-72 parts collector,…
Re: Sway bar touching airbags -- help!
Got any pics of the suspension? That might help.
06-02-2009, 06:58 PM | #3 |
Gonna subscribe to this thread as I have the same problem with stock A arms / bags with a stock sway bar ... I didn't fool with it long enough to find a solution, i just took the sway bar back off.
06-02-2009, 07:58 PM | #4 |
Can you cut the ends of the bar shorter? Seems like I remember the ends of my 73-up HD swap bar was a little past the bushing shells on the a-arms. Maybe you could trim them enough that it wouldn't interfere.
06-02-2009, 09:53 PM | #5 |
Maybe it was Frizzle, I'm not sure, but someone cut about 3/4" off each side of the sway bar due to touching the air bags. As you go lower, the bar is scooted back closer to the A-arms. Just cut the bar.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
06-03-2009, 12:47 AM | #6 |
Yep, good memory! I took about 1-1/8" off the ends and then bevelled the edges:
06-03-2009, 10:52 AM | #7 |
5150 had the same problem and it blew one of his bags. I think he just cut some off of the bar as well.
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
06-03-2009, 10:55 AM | #8 |
Yeah, I think it is either trim the bar ends or move the brackets, so I think trimming will be easier.
I will post pics as soon as I can find my cable for the camera. |
06-03-2009, 01:47 PM | #9 |
Resistance is Futile
I know CPP has issues.....but their sway bar uses endlinks and you dont have this problem. Just an FYI.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
06-03-2009, 02:17 PM | #10 |
you guys have perked my interest again but i'm gonna need some more parts ... anyone got a set of STOCK frame brackets they want to part with?
pm with a price. |
06-03-2009, 03:12 PM | #11 |
Addco sway bars have end links also. I think Nathan Porter can get you a deal on sway bars also.
06-03-2009, 04:52 PM | #12 |
Well, I just trimmed the bar ends 1 1/8" and that was the perfect length! The truck handles completely different and the bar is flush with the A-arm mounts. I documented trimming the bar, and will post pics later tonight.
06-03-2009, 10:08 PM | #13 |
Glad we could help.
07-13-2009, 06:48 AM | #14 |
Does anyone have pics of a cut sway bat installed?
i am wandering if the cut end of the sway bar digs into the bushing/bracket. |
07-13-2009, 05:06 PM | #15 |
pm
1967custom Last edited by michael bustamante; 07-13-2009 at 05:10 PM. |
07-13-2009, 05:12 PM | #16 |
Redefining LowBudget
I took the front sway bar bracket and moved it forward by makind the hanger look like a J the front bolt goes in the face of the hanger and the rear bolt got a new hole..I will say I had to trim the rubber on the A arm so I could clear it with the lower Arm to the X memeber
07-13-2009, 11:35 PM | #17 |
Follow the thread and you will end up with a bar like this:
This is with the suspension unloaded. With it loaded, the bar is flush with the bracket. Perfect length!
07-14-2009, 07:05 AM | #18 |
what type of sway bar do you have, irish?
i am running an ECE and my situation doesn't look like that. my bar is angled downward more, so the end would dig into the rubber bushing on the a-arm if i cut it back. once i get my bags on and sit lower it may line up straighter like yours. |
07-14-2009, 03:36 PM | #19 |
if your running cupped lowers that won't work look where the X memeber is is it goes to complete slam it will rest on the hanger and rubber mount........
07-14-2009, 06:27 PM | #20 |
I'm also running the ECE bar. The bar is at a larger angle when the truck is on jacks. take it off, and the bar will level out. That was the after pic. Before I trimmed the bar, it was pushing into the bags. Is that what yours is doing?
