Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-02-2009, 09:19 PM   #1
fast_dev
fast_dev's Avatar
what is my pinion angle????
found some very confusing and contradictory articles on the net, need help??? im using an angle finder and when i put it on the pinion yoke across where the cap mounts i get 10 degrees and on the bottom of the shaft i get 5 degrees. the pointer is on the same side of zero for both, what do i have??? Thanks, Devin
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 06-02-2009, 10:23 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: what is my pinion angle????
I've always done it by taking the angle from the yoke coming off the tranny, and adding it to the angle of the rearend yoke. So, if you had -2 coming off the tranny yoke and -2 off the rearend yoke, the total pinion angle is -4 degrees. I've never done it using the driveshaft method, so I may be totally wrong. I've always set my trucks up (the ones I've lowered) for somewhere between -2/-4 degrees.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
