06-02-2009, 09:41 PM | #1 |
Question on rear axle gear ratio
I have a Dana 60 rear diff. and I cannot find the BOM anywhere, nor the date of manufacture for that matter. I am trying to verify the gear ratio and the only thing I can find is a metal tab on one of the diff cover bolts that says:
41-10 4.10 I can only assume this means that it has a 4.10 ratio, but I would like to be sure. The truck is a '69 3/4T GMC with the 350/TH400 combo.
1969 GMC C2500 350/TH400 - Been in the family all its life. |
06-02-2009, 10:13 PM | #2 |
Gearhead and audio junkie
Re: Question on rear axle gear ratio
I'm pretty sure 41-10 means you've got 4.10's in the rear. Another way of checking is getting on the freeway and see if you can cruise at 65 mph without hitting 4000 rpm
06-02-2009, 10:23 PM | #3 |
Thanks. I would if I could, but the engine and tranny are out getting rebuilt. This is actually the reason for the question. I am trying to make an appropriate cam selection for the 383 I am building. I want to have power in the appropriate range for the gearing.
I don't (or didn't) have a tach in the truck, but it did seem to be wound up good at highway speeds. When I let off the gas it did slow down quickly. Hard to imagine since this truck spent most of its life with a camper in the bed traveling down the highway all around the country.
06-02-2009, 10:27 PM | #4 |
Hmm, I would think if its a camper special it'd probably have 4.10's to help it give it that extra grunt and actually 4.10's wouldn't be to bad for a little more racey cam. It'll help it build up from idle into it's power range quicker. If you are really worried you could build the engine how you want it and change the rear gears later on. Since your building a 383 you should have some more torque than your average 350 .
06-02-2009, 11:31 PM | #5 |
its all about the +6 inches
a camper special is a ford, or a later model GM...
A custom camper has nothing to do with gear ratios though, that option package is nothing but HD springs, shocks, tires, badging and an anti roll bar. the standard ratio in a 3/4 ton with a small block and an automatic is 4.10 gears. At 60 mph, the RPMs would be closer to 3000 RPM... not 4000. You can remove the cover and do a tooth count, that is the best way to find out whats in there, and if you just put the cover back on and roll with it, then you'll know the oil isn't 30 years old. I would ditch the Dana if that 383 is going to make much power, the axle shafts aren't all that strong. |
06-03-2009, 09:35 AM | #6 |
My "Dana" had a similar tag. Yes that is your tooth count and ratio.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
06-03-2009, 10:13 AM | #7 |
another quick check
1- jack up both wheels 2- place a chalk mark on the drive shaft and tire for reference 3- rotate the drive shaft 1 complete turn while watching how many times the tire rotates. (a little past 4 rotations would mean a 4.10) (a little less than 4 rotations would be a 3.73) (3 and 1/2 rotations would be a 3.50) ect. ect. this check would be for reference and get you close with out pulling the backing plate and counting ring and pinion teeth Andy |
06-03-2009, 10:27 AM | #8 |
It`s the ratio on that tag.That makes it easy.
Does your truck have leaf springs? My Custom Camper had the same rear and I ran it to the Grand Canyon North Rim from Maryland and back,It loved the hiway.Hauls the camper like it`s not there.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-03-2009 at 10:30 AM. |
06-03-2009, 11:00 AM | #9 |
41, 10 means there are 41 teeth on the ring gear and 10 teeth on the pinion gear. 41/10 = 4.10 or 4.10:1 ratio.
Certainly someone could have changed gears at some point but it started life as a 4.10. You can check by rotating the drive shaft (if installed), if it is a 4.10 it should take just over four revolutions of the drive shaft to rotate the driven wheel 1 full turn. |
06-03-2009, 11:34 PM | #10 |
Devil's in the Details
Or just take the diff cover off (you'll probably want to replace the fluid anyway if you don't know the history of the rear end) and count the teeth, or read the tooth number stamped into the ring gear. I had my D60 cover off last week, and clearly stamped into the ring gear was 49:10 as well as other numbers.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
06-04-2009, 05:56 AM | #11 |
why go through anything if the i.D. tag is right there staring at you?It`s a blessing.They usually aren`t there anymore because they get tossed when the cover comes off.I`m sure if the gears were swapped-out the tab would be long gone.Most likely the case has never been opened.
06-04-2009, 06:41 AM | #12 | |
This is likely to be the case. I am pretty sure I can trust the tag and assume the gear ratio hasn't been changed, but I'll probably pull the cover just to change the oil and clean things up. While I am there I can be sure.
Yes the truck has rear leaf springs. Are you suggesting that this is why I can't find a BOM on the axle? Quote:
11-15-2009, 10:56 AM | #13 | |
To check rear end ratio jack up one tire if you have an open diff, or both tires if you have a working posi or locking differential. Rotate the tire one full revolution for posis and lockers and 2 full revolutions for open diffs. Carefully count the number of full revolutions the driveshaft makes. This is your gear ratio. In other words, if the drive shaft turns 3 ¾ turns, you probably have a 3.73 gear ratio. Turning the tire for twice the number of full revolutions and dividing the drive shaft revolutions by two will give you a more accurate reading. Last edited by lakeroadster; 11-15-2009 at 10:59 AM. |
11-15-2009, 12:02 PM | #14 |
Moderator
Why would the method for posi and non posi be different? The gear ratio is a constant no matter which one you have.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
11-15-2009, 02:45 PM | #15 |
an open diff and a posi work different, the above is acurate.
11-15-2009, 03:17 PM | #16 |
Moderator
I have done it on both posi and non posi rear ends, and it comes out the same
My 72 SWB has posi, and it took just over three turns of the driveshaft to get the tires to make one full rotation, leading me to the conclusion it has 3.07 gears. The chassis I am restoring is an open diff, and it took 3 3/4 turns of the driveshaft to get one tire to make one full rotation, leading me to the conclusion it has 3.73 gears. When I did this, I had both tires off the ground in both cases...so should I do this on the non-posi diff with one tire on the ground? Is that what makes the difference?
11-15-2009, 05:11 PM | #17 |
If you jack up the rear axle and both wheels are off the ground the tires should turn in unison regardless of open/limited slip/locker. That is of course unless you have a brake dragging.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
11-15-2009, 05:21 PM | #18 |
Moderator
Yes....but the question is about how to determine gear ratio.
11-25-2009, 08:53 AM | #19 | |
The key to making this work is Rotate the tire one full revolution for posis and lockers and 2 full revolutions for open diffs. Last edited by lakeroadster; 11-25-2009 at 08:55 AM. |
11-25-2009, 09:21 AM | #20 | |
69 Chevy 4x4 383 Power |
