Old 06-02-2009, 10:34 PM   #1
Rogue_Sentinel
Rogue_Sentinel's Avatar
custom grille ?
so i have a chrome custom round tube grille that i need to put on my truck . but it dose not line up whit the holes on the truck and it not wide a enough to fit it . the box says it will fit my 79. this is the one have from lmc
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=66
http://s530.photobucket.com/albums/d...1.jpg&newest=1
the blue shows where the grille should blot to the truck
what do i need to do to make it fit ? cut sum of the grille off ? or is the grille missing sum thing ?
"Myths and legends die hard in America. We love them for the extra dimension they provide, the illusion of near-infinite possibility to erase the narrow confines of most men's reality. Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final."
Hunter S THompson
Rogue_Sentinel is offline   Reply With Quote
Old 06-02-2009, 11:39 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: custom grille ?
You should just use some sheet metal screws to attach it to the vertical supports you have circled in the pictures. If it doesn't fit the opening, then you probably bought the wrong one.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-03-2009, 12:11 AM   #3
Blazer Eagle
Re: custom grille ?
if yours is like mine and there are some brackets at the mounting point, try swapping them sides if they dont line up with the vertical supports, otherwise use the self tapping sheet metal srews
Blazer Eagle is offline   Reply With Quote
