Grandpa in the rustmobile...
truck not starting, symtoms inside
turn key on, volt meter at 12-13, turn key again to start, th UMD, and you dont hear the starter not turning over, do i have a bad starter?
for some reason im thinking sabotage edit, when i try to start it the temp. idiot light goes on for a minute
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 06-03-2009 at 11:51 AM. |
Re: truck not starting, symtoms inside
If it is a automatic I am thinking a bad neutral safety switch. Try turning the key to the start position as you move the shifter around but keep your foot on the brakes in case it decides to start in gear.
#3 | |
Active Member
![]() Join Date: Jul 2007
If you suspect that it's not the starter then something may be keeping the engine from turning. I'd use a breaker bar or similar and see if you can turn the crank shaft. Be sure and disconnect the distributor if you do this. The lights coming on while cranking I think is normal. |
okay turns out its the starter/solenoid, should i replace with new rebuild from autozone for 45$ with lifetime warantee, or should i use the OLD NASTY GREASY starter from my 72 parts truck....now, i gota 77 350cid motor in my 68, and orig. motor in my 72, will the starters interchange?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Active Member
If the starter you have is still good, I'd just replace the solenoid.
If it has the original starter and solenoid and want to keep it, you can have it rebuilt or you can do it yourself. In some of the old solenoids you could take the back off and flip the big copper contact washer that's inside over and keep using it. I've also sanded the contacts to make them work. All depends on how much you want to tinker with it... |
