Old 06-03-2009, 01:24 PM   #1
GMC406
Professional Grade
GMC406's Avatar
Can I wire my front markers to blink and run?
The PO of my truck wired the front marker lights into the blinkers aparently. With the way the turn signals are set up on these trucks thats accually not a bad idea. Catch is they dont come on with the marker lights. I love the way they look with all 4 markers on. Is there a way to wire them so they work as running lights and then blink with the turn signals as well?
61 GMC 9' Step
Someday it will be a build http://67-72chevytrucks.com/vboard/s...=1#post3356828
67 C-30 Red Dale motorhome http://67-72chevytrucks.com/vboard/s...31#post3845531
71 GMC Street performer in the works
Waiting for warm weather
http://67-72chevytrucks.com/vboard/s...d.php?t=341946
1990 GMC Sierra GT-sold
1983 chevy 4x4-project on hold maybe sell
1969 Triuph GT 6- sold
1996 Ford I-6 5 Speed 4x4
2004 Dodge Intrepid- milage maker
1959 Ford Fairlaine, factory a/c 292Yblock- sold
1982 Honda XL500R
Always lookin for other old trucks!
GMC406 is offline   Reply With Quote
Old 06-03-2009, 01:45 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Can I wire my front markers to blink and run?
What I recall seeing are side marker lights that blink opposite to the turn signal, like first the turn signal, then the side marker.
However, to do what I think you want, you'd need a bulb with two filaments; one for the turn signal function and the other for the marker. I don't know of any bulbs of the type that fit into the housing that have enough room for two filaments. Maybe someone else can help.
Member Nr. 2770
Old 06-03-2009, 02:33 PM   #3
wHATANERD
wHATANERD's Avatar
I've made a diagram of how you probaly make it work by adding a Botch Relay, and some additional wiring. Hope this helps.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 06-03-2009, 02:33 PM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yes if someone chimes in with a wiring diagram and you wire it up correctly the fronts will flash when your turn. The rears are not suppose to flash. It sounds like someone wired it wrong.
You need an oem wiring diagram
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 06-03-2009, 03:17 PM   #5
Joeys Toy
Joeys Toy's Avatar
Move the wire from the bulb that is presently grounded to the body to the wire that is hot when your running lights are on. The light will work as you want but as stated above, will flash opposite of the turn lights. The single filiment bulb is all you need. Sounds crazy without a wire going to ground but the bulb will ground back through the circuit that is off.
Joeys Toy is offline   Reply With Quote
Old 06-03-2009, 03:50 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Joeys Toy is 100% right. No relay, no daul filament lamps... none of that.
68 - 72 trucks had the front side markers wired 2 ways. i have found no reason why they were done like this, but I have found it to be fact.
one way, the front side markers are steady burning with the parking lights. my 70 one ton is like that.
The otherway, the side marker will blink WITh the turn signals with the parking lights off, then they will blink in oposition of the turn signals when the parking light is on.
Again, lke Joey said, one wire from the marker will go to the parking light wire, and the other side marker light wire goes to the turn signal wire.
This is how the factory did it when the factory markers blink. No relays, no fancy lamps, just simple wiring
Old 06-03-2009, 04:58 PM   #7
wHATANERD
wHATANERD's Avatar
Thanks for the info LHM, that's alot simplier than what I was thinking.
Old 06-03-2009, 06:44 PM   #8
68 Stepside
huh?
68 Stepside's Avatar
I agree as well. My 68 didn't have marker lights for some reason, no place for them either, just lenses. So I went to the auto parts store, bought two 194 bulbs, and two 194 sockets that fit the marker lights, wired one wire into the parking light side of the front turn signal, and the other wire into the turn signal side. Worked like a charm.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-03-2009, 07:36 PM   #9
GMC406
Professional Grade
GMC406's Avatar
Thanks all, got them working properly. Almost got the PO wiring chops gone, just an all new tailight wiring harness and im set!
61 GMC 9' Step
1982 Honda XL500R
Old 06-03-2009, 08:45 PM   #10
Mayo
Cool Truck
Mayo's Avatar
I might have to try that when I get mine wired up.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 06-03-2009, 10:12 PM   #11
Longhorn Man
I failed to put the disclaimer on that post... 68 & 69 trucks had no lights unless they were specificly ordered. The only exception was if you got a cab/chassis with the daul rear wheel option. Then you were required to get (at added cost) the side markers, and the roof mounted clearance/ID lights.
