Old 06-03-2009, 03:02 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Rearend swap, rebuild, powdercoat project
I recently did a thread on my conversion to late model front suspension with rebuild and powdercoat work. I figured since that part of the project is done, I'd start a thread on the rear conversion process. This process will likely take a week or two since parts are so expensive and I have to scrape up the extra coin to buy as I go. I will update the thread as I make progress like I did the front end swap on the earlier thread.
I started with an 80 model 12 bolt rear differential out of a leaf spring truck (obviously, since all 80 models are leaf springs). I am going to completely rebuild this thing and install it into my coil spring equipped 63 truck to get highway gears and 5 lug wheel pattern.
First, I spent some time cutting and grinding all of the leaf spring pads and shock mounts off the donor unit.
Then, I tore the unit completely apart, removing everything from the housing. I will replace all seals and bearings, so no worry about damaging the old units. I need the housing completely bare to degrease it and powdercoat it.
I cleaned all of the internal stuff to evaluate what needs to be replaced and what can be reused.
Old 06-03-2009, 03:07 PM   #2
Tx Firefighter
Re: Rearend swap, rebuild, powdercoat project
Next, I bought a set of Early Classic Enterprises rear end saddles. These things are just the ticket to put a generic axle into a coil spring truck.
I centered it under the truck and set the pinion angle and tack welded the saddles into place. Then, I removed the whole unit and welded the saddles permanently into place. Not my finest welding, but solid and not going to fail.
Now, I put the housing into the oven to cook it at 500 degrees for an hour. This will bake any remaining grease or oil out of the nooks and crannies.
It's in the oven now, so hopefully later tonight, after it cools enough, I can get it sandblasted and powdercoated. If not tonight, that will be the goal for tomorrow.
After that, a trip to the parts store to buy new pinion and axle seals, carrier, pinion, and axle bearings, and cover gasket.
Old 06-03-2009, 03:27 PM   #3
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Is that a home made oven? and if so do you have a link on how you built it. I know some people that want to build one!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 06-03-2009, 03:33 PM   #4
Tx Firefighter
My buddy built it in his shop. It's just basic welding and fabricating. There is a lot of information on the net about building them to go by.
Old 06-03-2009, 03:43 PM   #5
forestb
forestb's Avatar
I'm Sorry what is the point of the oven? and are those saddles for the 63's and up or will they work on a 62 also?
forestb is offline   Reply With Quote
Old 06-03-2009, 03:49 PM   #6
Tx Firefighter
The oven is twofold. One, it bakes off any grease and oil to get the surface ready to accept the powdercoat. Two, it is how you cure powdercoat. You have to hold the part temperature at 400 degrees for 20 minutes to cure the powder. Once it is baked grease free, I will sandblast the housing and apply the powder, then back into the oven again.
The saddles will fit an coil spring rear GM truck.
Old 06-03-2009, 05:43 PM   #7
daverod
SSN 706
daverod's Avatar
Just bought me a 71. sub. $300 and it runs. I was holding off because I did'nt know if the rear end would work in my 66. All I have to do is watch you and I have it made. My welding sucks so I think I might let someone else do the welding. Keep up the good work. Wish you were closer I'd let you do powder coating.
daverod is offline   Reply With Quote
Old 06-03-2009, 06:11 PM   #8
ruffrida2005
where is Springtown near? I'm in Killeen!
Paul
Old 06-03-2009, 07:57 PM   #9
Tx Firefighter
Well, good progress in the last few hours. It is now blasted and powdercoated...
Hopefully tomorrow, I can get some bearings and seals and start reassembling it.
Old 06-03-2009, 08:19 PM   #10
TR65
TR65's Avatar
Man, Nice work Kevin.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 06-03-2009, 08:47 PM   #11
daverod
SSN 706
daverod's Avatar
What angle did you set the pinion at?
Old 06-03-2009, 08:50 PM   #12
slepysal
slepysal's Avatar
very nice work,Tx dig the attention to detail. What did you use to cut the leaf spring perches off?
I am trying to scrapr up some $$$ to have Chief install the 67 rear end into my 60.
Oh and forestb the saddles are the same 60-72, they are just spaced diffrent on the 60-62's
Keep up the good work Tx
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 06-03-2009, 09:06 PM   #13
Tx Firefighter
I did it a way that is hard to explain. I set the original rearend on the bench and made sure the axle saddles were perfectly level. Then, I measured the pinion angle and found it to point up 10 degrees from level. On the new rearend, I just made sure that with the new saddles perfectly level, the pinion pointed up 10 degrees. I don't know what the angle will be once installed, but it will be exactly what the original angle was on the original rearend.
I used a torch to remove a bulk of the original saddles, then a grinder with a flap wheel to buff off the remaining remnants. I had no need to save the saddles for reuse, so I could be pretty crude on removing them.
Old 06-03-2009, 09:16 PM   #14
Tx Firefighter
I went ahead and did one more thing tonight before shutting off the lights. I powdercoated the cover in ultimate chrome. I'm too poor to afford a real chrome cover, so a refurbished original cover will have to do. Bad pictures though. It looks fine in person.
Old 06-03-2009, 09:45 PM   #15
padresag
you can usually take old perches off with a hammer from the underside on one side and it should just peel off at the weld and grind it.
if the perchs are going in at the same angle as the old ones do the one side at a time then you can use 2 straight sticks across the perches and eyeball till the sticks balance out across the housing
ron
padresag is offline   Reply With Quote
Old 06-03-2009, 09:46 PM   #16
TexC-10
TexC-10's Avatar
You're my hero!
TexC-10 is offline   Reply With Quote
Old 06-03-2009, 10:30 PM   #17
rustyescott
rustyescott's Avatar
Smile Re: Rearend swap, rebuild, powdercoat project
damm good work
rustyescott is offline   Reply With Quote
Old 06-03-2009, 10:37 PM   #18
joe231
joe231's Avatar
very nice work...and fast, you seem very efficient
CHEVY ONLY
Old 06-04-2009, 03:11 AM   #19
sams60gmc
sams60gmc's Avatar
Looks great man. Makes me want to get motivated to go get mine all ready to put in!
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
