Old 06-03-2009, 06:49 PM   #1
heavy71chevy
heavy71chevy's Avatar
seperating pistons and rods
whats the best way to get them apart...i tried tapping the pins out but got nowhere.thanks
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 06-03-2009, 06:56 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: seperating pistons and rods
You have to have them pressed out by machine shop. They will also install the new pistons if that's what you need to do. Don't try to whack them out. You'll ruin both the pistons and the wrist pins.
68gmsee is offline   Reply With Quote
Old 06-03-2009, 07:13 PM   #3
LONGHAIR
68gmsee is right. They are actually what is called an "interference fit" meaning that the pin is bigger than the hole in the connecting rod. The small end of the rod must be heated in order to get the pin either in or out.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-03-2009, 11:33 PM   #4
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Get a large caliber rifle and fire right at the pin! Preferably with a .50cal
Just kidding. Take em to your local machine shop I don't think theyd charge you much to push em out
mikajo39 is offline   Reply With Quote
Old 06-04-2009, 06:14 AM   #5
jim zag
ENGINE BUILDER
jim zag's Avatar
You need a press to get them off the rods. The machine shop can use a rod heater to install the pistons or I have a special OTC setup that reaches inside the piston and holds the rod and presses the pin through without damaging the piston.
JIM ZAG
jim zag is offline   Reply With Quote
