Turn signal issue
82 gmc c15
Ok the problem is that when i activate the right turn signal or the hazards it blows out the turn signal and hazard fuse. Trying to isolate the problem.
The left side still works great. Do you guys have any ideas on what to test? Could the charging system surge cause the hazard/stop fuse to blow?Why i ask is i had all the signals working. 5 min later i take it to the inspection shop around the corner and both fuses are blown which brings me to my current state.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) Last edited by Cherub; 06-03-2009 at 07:01 PM. |
Re: Turn signal issue
Have you checked the wiring and connections in your steering column?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Yes and i dont see anything out of the norm.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
the pollock
it will blow the fuze on a short not a ground..
i know it seems dumb.. but an easy way will be connect a multimeter and check for shorting between the positives leads at the bulb to the rad support..etc.. or you can check the lights when it's dark out.. and use a couple fuzes to see if there's a "spark" under your hood hehehhehe
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
Cheyenne Super
#6 | |
No i havend pulled the steering wheel. Good idea about pulling the lighting from the engine bay fuse connection. Ill try that when i get home and see what happens.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) Last edited by Cherub; 06-04-2009 at 02:56 PM. |
Ok i disonectd he lights at the fuse block. fuse didnt pop. connectd the font lights and the right side was dim but didnt blow.connected just the rear and the fuse blew. The left side works fine so i think i have it narrowed down to the rear right side
the pollock
oh wow that's going to be fun finding that short.....
Try replacing the headlight switch. I had this problem but i replaced the switch and It now works perfect.
76 Chevy 355 Vortec Heads |
#10 | |
Cheyenne Super
but the amp draw from the rear could have been the straw that, blew the fuse. Sometimes those round trailer plugs get loose wires inside, but I guess you would have checked that. |
I got the issue fixed. After Isolating that it was coming from the rear i started pulling the loom that runs from the back to the fuse block. As im de tangleing it it feels like its snagged on something. At closer inspection the loom has been pinched by my c notch bolt and has grounded out....yep you guessed it the right rear wire (dk green)
![]() I appriciate the help isolating the issue.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) Last edited by Cherub; 06-05-2009 at 03:45 PM. |
