welding advice needed!!!
Gents,
I figure why not go all out on my '67 stepside... [I've decided that i'm going to learn how to weld. ![]() Thanks, Chris |
I am a Referee of life.
Re: welding advice needed!!!
For the hobbyist a MIG is probably the way to go for bodywork.TIG is definitely the most challenging and makes very clean welds but costs much more to set up.Do a search on Miller and maybe Lincoln welders and see if the info they give helps you determine what's best for you and what you want to do.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 06-03-2009 at 08:53 PM. |
There is a sticky for this question http://67-72chevytrucks.com/vboard/s...d.php?t=146163
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
ENGINE BUILDER
Buy yourself a NICE MIG welder and PRACTICE, PRACTICE, PRACTICE!!!!
JIM ZAG |
#5 | |
AMEN to that brutha ![]()
Horsepower sells cars Torque wins races |
cool. read through that entire sticky on welding... looks like i'll go with a mig... possibly a lincoln... not sure yet... thanks guys.
![]() Join Date: Apr 2001
MIG is definetly going to be the way to go, I am an industrial tech teacher and have worked professionally as a welder in industry for three years..... Make sure the welder can use both .023" wire and .035" wire.... I also spend a little extra cash and pick up a Miller, Lincoln, or ESAB unit with at least 140 amps. I have been forced to use some of the cheaper units at school and they have not held up very well. It becomes difficult to learn to weld when your welder makes things that much more difficult. I would also stay away from a gas-less welding system and opt for a small tank of CO2 (cheaper) or a 75%Argon 25%CO2 mixture (preferred). Any welding jobber worth their salt can be of assistance with that. Both Miller and Lincoln have some great online resources for the beginner and I recommend looking at them wholeheartedly. If you have a list of part numbers I would be happy to take a peek at them and make any recommendations. I would not be out to waste your money. Good luck and Ill hep out any way I can...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
Mike,
thanks for the tips. I'm scouring through all sorts of resources online... That's why I'd rather get 1st hand advice from guys that are doing it.... I'm going to look at a few lincoln's and see what I come up with. -Chris |
adult education courses/
yup. just called a place local to me in CT. they are booked solid for weekend courses through september.
I use a tig, or oxy fuel with 00-#2 tip. The welds are softer,and can be dollied without cracking.
Works well. If your just wanting to mig. .023 wire is perfect for mig sheetmetal , .035-.045 for frames and structural. BH |
http://www.allmetalshaping.com/showthread.php?t=253
Just incase you may be interested. Torch welding sheet metal discussion. BH |
#13 |
![]() Join Date: Apr 2009
Get a Miller I have a Miller 140, and a Lincon 185 and a Lincon Ranger in my Work Truck. like the Miller better started welding at 12 years old. Got a free Snap On Auto darking helmet real lite....
#14 |
I have a miller 180 mig and it works great.
Also, for body work they make an "easy grind" wire. (don't use it for structural stuff) |
#15 |
ok here's a question.... if I buy from lowe's or home depot vs. a welding joint.... i know that the welding place is commercial grade where lowe's isn't. Is there a big difference for someone like me that won't be using this thing everyday?
#16 |
Is the Hobart 140 not a good choice?
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#17 |
I was looking at the Hobart 140 before I found my Miller 135. Looked to be a decent machine and of good quality from the people I talked to. I went with the miller for the name and extra (was used vs new of the 140) and because I have a friend who has one and showed me the basics on it. That being said, I've only ever welded 2 pieces of metal for practice as I just got this one a week or so ago.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
#18 | |
If your buying from a welding outfitter, they will usually answer all the questions you may have, give you tips, and get you started in the right direction. They probably won't like supporting someone elses machine. Support from Lowes or Home Depot is great if you're putting up a deck, fixing your toilet, or adding a nice herb garden. J/K ![]() They MIGHT be able to answer the most general of questions depending on who they are, and what they have done in the past when it comes to welders and welding.
Horsepower sells cars Torque wins races Last edited by deweychop; 06-05-2009 at 11:17 AM. Reason: fingers type TOO FAST |
#19 |
i completely agree with above/ plus they maybe can hook you up with tech classes and seminars from the manufacture as well as other classes you may not know about and they're a good source of knowledge for local supplies of materials// many times they have deals available on trade ins and factory reconditioned machines// they normallyy have racks full off cool gizmo accessory stuff too
another thing for schools you might want to check with some local racetracks if they know of summer welding classes// thompson speedway stafford springs waterford theres lots of fab shops building cars for these tracks//the welders have to come from somewhere
#20 |
Certified Car Nut
I have a Hobart 180 and I love it. The Hobart welders are owned by Millers, they even come with a Miller gun. The Hobart is a nice machine, but Miller is the top dog. The only other welder I would want over my Hobart would be a Millers, just to say I have one.lol Because my Hobart does everything I need it to do.
#21 |
I too would go to a welding supply store, or two, or three. Ask to talk to the tech, that repairs them. Ask them of all the units in the under 160volt range that are least in the shop for repairs.
Then what are his top choice for the $$$. Thats what I would do, if I di not know any better. Plus, you'll know who your talking to if you ever do need a repair. Be honest and let them know your a part timer, and don't need a 60-100% duty cycle machine. Bill |
#22 |
bought my lincon from home depot . It was one of those package deals. The best price i could find. But a welding equipment dealer will be more useful with his knowledge of the equipment.. Be sure to be honest with yourself on how much are you going to use it and what type of work you will seriously use it for. No need in buying a high price tig if you are going to fill in holes and do some mild fab work..
#23 |
![]() Join Date: Sep 2002
I bought my lincoln 125hd at Home Depot as well, great welder. I use gas and did wire a dedicated 20 amp circuit just for the welder and I do notice a big difference. We have the same welder at work and I dont think it cracks as nice as mine does on a dedicated circuit. As far as using it everyday, we use ours at work everyday from exhaust to sheetmetal to fabricating. Its never let us down yet, No its not a $5,000.00 welder its a $400.00 welder but it'll throw down a row of coins as nice as a more expensive model.
67' Chevy C10 Lwb small rear window 71' Gmc 1500 custom 4x4 72' Gmc Grande Sierra |
#24 |
You can't go wrong buying a Miller for your first welder. If you buy it at a Home improvement store or a welding supply the same model is the same model. The welding stores will help you even if you don't purchase it their. We do. Sometimes they will sell the exact same welder for the same price on sale. Sometimes they have great deals on better welders. Most welding shops don't really care where you bought it.
Not Related to Subject: You hear people say OLD SCHOOL or NEW SCHOOL? The New school welders have it easier today. Only when doing pipeline welding when they say "We are old schooling this Project" Then the New School or Old school guys better not have a failed weld. If they do they are fired and will never be hired back. It means a 100% passed job. Today they will allow the new school pipeliners One failed weld. Life was tougher back then for welders. Usually ![]() |
#25 |
I just bought a Hobart Handler 210 a month ago. It's the biggest portable machine available, so far so good!
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
