06-03-2009, 09:58 PM | #1 |
I hate color sanding
But the results are great. I did a quicky on this one. I could probably go at it more and might in a few days. I had a small burn through but the clear was real thin there. I will just touch it up later. In the 2nd picture you can acually see my truck at the top of the fender. My truck was parked about 10' away.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-03-2009, 10:02 PM | #2 |
SSN 706
Re: I hate color sanding
Ok I'm a moron. Whats the purpose of color sanding? It does look good.
06-03-2009, 10:05 PM | #3 |
maybe I should take a picture of the other fender so you can see.
It takes the orange peel away and makes it smooth as glass.
06-03-2009, 10:11 PM | #4 |
SSN 706
What grit do you use? Do you wet sand it? Is it somthing you always have to do or just where you have orange peel? kinda like that color whats it called?
06-03-2009, 10:22 PM | #5 |
Here is a picture of the other fender. It is not sanded yet. I dont know if the pictures will do it justice or not but I think you can see the differnce. The 2nd picture is the unsanded one. I started with 800 to really break it down then switched to 2000 and buffed it out. If you dont use them right you can burn through the paint.
It is a 1991 GM color. I will look next time I have the paint out.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 06-03-2009 at 10:23 PM. |
06-03-2009, 10:34 PM | #6 |
Cool!
the sanded one looks nice and slick!
CHEVY ONLY |
06-03-2009, 10:36 PM | #7 |
SSN 706
Now I know. The sanding makes it look a lot better. Just what I wanted to here more sanding to be done. You wet sand it right?
06-03-2009, 10:38 PM | #8 |
1 thing at a time is progress.
I hear ya on color sanding. I don't care for buffing much either. Awesome job.
Alan
Philippians 2:14-16 |
06-03-2009, 10:43 PM | #9 |
Yes wet sand. I just use a spray bottle and keep spraying. Man my fingers are raw.
06-04-2009, 07:12 AM | #10 |
Rods
i use a 3m wet block when I color sand...but I cheat now I use the 3m dry system. the only water I use is with the 3000 grit
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
06-04-2009, 07:53 AM | #11 |
One day...
I cheat too, 3000 on a DA on flat surfaces
06-04-2009, 09:09 AM | #12 |
Hollister, CA.
Nice job...bring those to Vaca....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
06-04-2009, 09:13 AM | #13 |
Rods
well i have been known to double up on an interface pad when im in a pinch for a curve.
06-04-2009, 11:16 AM | #14 |
you guys and your body talk
CHEVY ONLY |
06-04-2009, 12:30 PM | #15 |
Why?... Do you want to see my ****ty work. They look good in pictures...
