![]() Join Date: Apr 2007
help with pinion shaft thickness!!
Im about to order up a set of gears for my 69 but it looks like 2 different pinion shaft sizes were used in the 12 bolt over the years. 1.438 in. & 1.436 in.
The rear end in my truck is a stock 1969 12 bolt. What size do I have? Thanks.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
Re: help with pinion shaft thickness!!
Ok figured it out, I guess it depends on the carrier you have. I have a 3:40 or lower carrier so its the 1.438" pinion shaft or 3 series carrier. The stock carrier for my truck for the 3:90 was a 4 series carrier, thats the 1.436 dia pinion shaft. Thanks for looking guys, have a great one!
I only know car vs truck. 1.625 vs 1.438
I find strange that the pinion shaft on a car 12 bolt would be thicker. It should be the opposite imo.
It may not be based on the load that could be hauled but the relative gear ratios. Lower gears in trucks (higher numerically) likely apply a smaller torsional load to the pinion than a higher gear in a car.
good point.
Six in a row makes it go...
![]() Join Date: Mar 2009
Yeah, but .002 inch? That's probably within the tolerance on the diameter.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
yea .oo2 is hardly anything. that's thinner than a piece of paper.
