Old 06-04-2009, 04:41 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
truck wont start still...
im getting fire, getting gas and air, under dizzy cap is turning rotor button is good looking.....WHY WONT MY TRUCK START!!!!
first i had a bad starter, 50 bucks later, a few choice words, and 45minutes of my time, i gotta new starter on....
now at least it turns over...but still wont run...any ideas
John
1999 Toyota Tacoma 4x4
Old 06-04-2009, 04:46 PM   #2
matchstick
matchstick's Avatar
Re: truck wont start still...
IS it flooded? If you're getting gas and spark you should be running.
matchstick is offline   Reply With Quote
Old 06-04-2009, 04:49 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
What kind of distributor do you have?
You said you are getting fire, is it to the plugs?
Has the truck ran and now won't start? If so what has changed since it ran.
Sorry for all the questions, but a little more info is necessary to better help you.
I have heard on here before in order for an engine to run it needs fire, air and gasoline. Also it has to be firing at the right time.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-04-2009, 04:56 PM   #4
oldblue1968chevy
electric i guess hei dizy
parked it the other night to jump a wheeler off, left it where i pakred it went out the next am to get a haircut and it wouldnt turn over, well today i went to buy a starter, put starter on, now it turns over but still doesnt start,
gets fire at the plugs
dumped gas in it, and it gets gas
nothings changed since it ran last lol, cept a new starter, and me movin the dizzy retard/advance......
John
Old 06-04-2009, 05:13 PM   #5
sandking
.....I am working on it.....
sandking's Avatar
Timing, timing chain, fuel to the carb, screen in the carb inlet, choke stuck, etc.
Have you checked the fuel level in the carb bowl(s)?
Have you checked spark at all plugs?
View my build thread HERE
sandking is offline   Reply With Quote
Old 06-04-2009, 05:39 PM   #6
oldblue1968chevy
havent checked spark at all plugs
i can see a lil gas in bottom of carb
screen in carb......ive dumped gas in it, but it may be getting stuck at the screen
its an electric choke.......its not even hooked up lol
John
Old 06-04-2009, 05:43 PM   #7
cdowns
cdowns's Avatar
checked spark at how many plugs// HEI or points distributor?
Old 06-04-2009, 06:21 PM   #8
oldblue1968chevy
just #1 plug
hei
John
Old 06-04-2009, 08:21 PM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
take the air cleaner off and flip the thottle a few time and see if it's squiting gas...if you have gas and spark you have a runner.....is the carb pump doesn't squirt start checking you fuel system
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-04-2009, 10:45 PM   #10
69halfton
69halfton's Avatar
does it do anything? kick? sputter? show SOME signs of life or nothing at all?
id check all the plugs to looks for spark. even just check that all the plug wires are on. there has been stupider things happen that will keep a truck from starting. ask me how i know.
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 06-05-2009, 12:04 AM   #11
tim21391
tim21391's Avatar
on my dads 67 mustang.. a vacuum line popped off and so it wouldnt start... maybe it can be something that small.. maybe that pcv valve came out or something
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-05-2009, 05:54 AM   #12
dznucks
dznucks's Avatar
you say you jumped a 4-wheeler off......you might want to check your dizzy. i have seen a dizzy fry before just by jumping off another vehicle. i would take the module out and test it.
dznucks is offline   Reply With Quote
Old 06-05-2009, 11:50 AM   #13
oldblue1968chevy
checked the dizzy..
why would it fry from jumping something off?!!!
ive gotta nother one i can exchange......
will go play more when i feel like stomping in the mud (its nasty outside)
John
Old 06-05-2009, 01:08 PM   #14
oldblue1968chevy
well, turned out it was my type of working on the truck lol
went out, sat down in seat to think, turned key...and bam it started lol
now we've fooled with the carb. soo much its way out....wont even hardly run...
anybody have any kind of idea the settings are supposed to be, its got 2 screws on the front, which are currently all the way screwed in...im bout to google it to see what comes up, id like to know even wat the diff. are which one leans/richs it out
John
Old 06-05-2009, 01:28 PM   #15
WorkinLonghorn
WorkinLonghorn's Avatar
I think both idle air screws should be turned 2 turns out to start with,then fine tune from there to smoothest idle or highest vacuum if you have a gauge.
It will not run with them both turned in all the way.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-05-2009, 02:39 PM   #16
UltraBlue71
UltraBlue71's Avatar
I have had spark fuel timing everything working and not have the engine run, you need compression too, if the rings are shot she wont run, I learned that on a S-10 a while back hooked up the comp gauge and had 0-5 psi in each cylinder, the PO had run her out of oill and the rings are gone, not typical, mind you but it happened to me!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 06-05-2009, 06:17 PM   #17
Shyguy
Junior Member
Shyguy's Avatar
Yep, you are right no compression-no run.
Good point.
That is what I like about this site, everything is brought up at one point or other.
Danny
Old 06-05-2009, 06:21 PM   #18
oldblue1968chevy
runs good now...but i didnt add oil and i have 0 oil pressure...when i rev it the oil pressure gauge goes up like a tach. lol its aftermarket guage...and dipstick reads a lil too much oil, whats that saying?
John
Old 06-05-2009, 08:02 PM   #19
Boog
laying low
Boog's Avatar
Uh oh. Too much oil and you didn't add any? Is the oil milky looking? How's the radiator coolant level? Does the engine rattle or knock?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-05-2009, 09:01 PM   #20
big mike71
big mike71's Avatar
If they were scewed all the way in you probably fouled your plugs.
big mike71 is offline   Reply With Quote
Old 06-06-2009, 09:59 AM   #21
oldblue1968chevy
no i just screwed em in never ran it like that
i did get it running
i had gas in my oil,ima change fuel pumps today (try to atleast) and may change carbs for awhile (goin back to quadrajet from edelbrcok)
anybody know how im getin gas n the oil?
i flushed it out, drove it fro bout 1.5 mi with oilygas then flushed it, will flush again soon tho
John
Old 06-06-2009, 10:31 AM   #22
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
How much fuel did you pour in the carb trying to get it running? And how many miles does the engine have on it? Just a guess, but you may have poured so much fuel in that it seeped by the rings into the crankcase. Seen it happen before.
As far as reading 0 psi at idle, there was probably enough fuel in the oil to thin the oil out. Get fresh oil and a new filter on there ASAP.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-07-2009, 08:12 AM   #23
RustyParts
RustyParts's Avatar
Gas can also get in the oil pan from a ruptured diaphram in the fuel pump.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 06-07-2009, 08:34 AM   #24
truckdude239
truckdude239's Avatar
if u ran it with gass in the oil for 1.5 mile you looking at min a bottom end rebuild gas will wipe you bearings in a heart beat causeing a no oil pressure at idle
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-07-2009, 09:03 AM   #25
69halfton
69halfton's Avatar
oldblue, when you said jumping off, I think dznucks thought you ment jump started with cables. where I think you ment jumped off as in drove off the back of the truck. which you are right, would not effect anything
..just to clear things up..
- Jason
Favorite caption:
