Sb 400 club
getting font brake drag on the 77 k10. It disc front end and I get the smell of pads dragging on the disc. Pins are greased and the calipers move freely. Any ideas???
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
78 Big10 454
![]() Join Date: Jul 2008
Re: brake dragg
Hey, 84, had a problem similar to yours and found two problems that were easily addressed. First, the caliper wasn't tightened like it should have been and, Second, I had a bad wheel bearing. The root of the problem was most likely the loose caliper... or it could have been a combination of the two...I'm no Sherlock Holmes, but at least it solved the problem!
Cheyenne Super
Re: brake dragg
My money is on the rubber brake lines/hoses. They get bubbles in them that
pinch off the flow, I see that problem all the time. |
#4 | |
Arrived on a Pale Horse
Re: brake dragg
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: brake drag
im going to third the rubber lines idea its happened to me the bad wheel bearing will make the inner pad wear out fast
78 Big10 454
Re: brake drag
Darn, outvoted!
Kid's Mechanic
Re: brake drag
in the past, my trucks.
2 bad brake hose's 3 stuck brake calipers if you crack the bleeder screw open on the suspect caliper and it turns loose bad hose.if its still tight, caliper Last edited by powerdriver 1958; 06-05-2009 at 07:36 PM. |
Crew Cut
Re: brake drag
x5 on the hoses
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
#9 | |
Re: brake drag
Frank
Born and proudly residing in a Red State ! |
Re: brake drag
yea, thats how i wrecked mine
82 c/10 project ![]() 03 silverado daily ![]() |
Re: brake drag
You drove it with the bleeders open?
Re: brake drag
The hoses would be the place to start. Crack the bleeders , like stated before, let them sit to gravity bleed the brakes. Close them off and check pedal travel , down and up. Look to see if the pedal returns to the top. The master cylinder square cut seal could be binding and not releasing the calipers fully.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#13 |
Re: brake drag
no no my pass side brake liine collapsed on me
#14 |
Re: brake drag
Ok, you scared me for a minute...
