Champagne Taste on Beer Budget
I bought my HEI distrubitor 2nd hand and all I did was replace the cap, rotor and coil cover. My question is do I have to ground it somehow? I mean I saw in some of the conversion pics that there was a ground wire added to them.
Well mine has a ground wire as shown in this picture and I don't think I need to add one now do I? Thanks in advance!
Coming Soon: Project 1970 Country Truck Last edited by C20-67_N_MO; 06-05-2009 at 02:32 PM. |
![]() Join Date: Dec 2006
Re: HEI Setup Question
That's all mine has. Just make sure the connection is clean with no corrosion etc.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
Active Member
![]() Join Date: Jul 2007
It's grounded from that connector through distributor frame and down to the engine block.
On mine, I just made sure that the base where it contacts the block was clean and there was metal to metal contact. I also lightly sanded the bottom of the clamp and polished the threads on the bolt to the engine block. Not sure you need to do all that though. |
Okay cool then I am covered then.
Thanks guys!
Coming Soon: Project 1970 Country Truck |
sharp as a marble
![]() Join Date: Jan 2007
in your picture, there are 3 tangs, that get connected to the wiring from the distributor, and from your 12v+ source. The center one is a ground strap that is between the coil and the distributor cap. This is the ground for your distributor.
ENGINE BUILDER
You should be good to GO!
JIM ZAG |
