06-05-2009, 02:35 PM | #1 |
does anyone have pics of someone running 18 and 20s?
I have a chance to trade my 22s for some coy c5s 18x8 in the front and 20x10s for the rear, I was just wondering about how it would look...
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
06-05-2009, 03:51 PM | #2 |
Re: does anyone have pics of someone running 18 and 20s?
It doesnt look right unless your truck is dropped hard.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
06-05-2009, 05:08 PM | #3 |
this is the drop I have now, and if I get the 18,20s I am going to drop it 3 more inch in the front and 5 more in the back.
06-05-2009, 07:36 PM | #4 |
i think SCOTI has 18/20 combo
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
06-06-2009, 10:57 PM | #5 |
Happy to be here
I think you need to leave that Burb alone. I am all about lowered vehicles, but the stance and wheels are a great combo.
Since your probably not going to listen to that advice, here ya go.
06-06-2009, 11:39 PM | #6 |
6.0 powered square
looks good how it is
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
06-06-2009, 11:42 PM | #7 |
It'd be alot cooler if you did
I really think the staggered look is over rated, I ran a 18/20 combo on one of my previous trucks, and it was slammed.... I really grew to hate it.
06-06-2009, 11:45 PM | #8 |
Cheyenne Super
x3 leave it alone.
06-07-2009, 01:22 AM | #9 |
Recently, I swapped some 20" Coy's on it & had to creep along because there was zero clearance (ok, there was .500"). It buzzed the tops of the inner wells just creeping down my alley. It would require raising the inner wells for extra clearance @ that ride height which I did not want to get into @ this time.
I did the 18/20 deal because the truck is driven daily. I wanted a minimum sidewall height & it needed to fit w/o rubbing. After trying the 20" Coy's, I was still looking for a change. I cleaned up some 15" ralleys that were on my beater & have had them on ever since. I'm diggin' the old school look these days. Ken . . .... That's a good pic BTW (I haven't seen it before). Right click.... save. Thanks
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-07-2009 at 01:24 AM. |
06-07-2009, 08:12 AM | #10 | |
Happy to be here
Guys, Scoti knows I love his truck and how it looks. That's why I feel comfortable using it as an example. It allows me to point out what I mean when I talk about an 18/20 combo and how they fit our trucks. It doesn't look bad if it's tucked, but it really makes the front tire/wheel look small when it's not.
06-07-2009, 11:19 AM | #11 | |
And just for the record, I do love Scoti's truck, and can understand running the set up for daily driving issues. Actually that was the same reason I ended up running the staggered set up my self. |
06-12-2009, 12:20 PM | #12 |
the reason I want to go this way is because I am going to bag it and I want to keep the a/c and heat. I cant run 22s and keep the ac...
06-13-2009, 10:48 AM | #13 | |
I'm sure you have posted it before...but I got a memory problem Is it static? what is the drop? got pics of the 15's on it? Thanks!
CHEVY ONLY |
06-13-2009, 11:06 AM | #14 |
Here's the progression. I thought I had some pics of it when I brought it home but I must not have loaded them from the camera to the computer.
The drop is 3" Bell Tech spindles w/1-coil cut from the OE springs, an HD 1.25" OE sway bar in poly bushings, relocated/home built upper shock mounts for more shock travel w/stock replacement type gas shocks. The rear is the OE 8-leaf HD set-up w/a Western Chassis flip kit, Bell Tech shackles, & W.C. shock extensions. I modified some Western Chassis bolt-in c-sections by adding upper bag brackets for a 'primative' AOL set-up that uses the smaller 6" Firestone bags when I need to tow my trailer. The shocks are the same style as the fronts but the p/n was for a 73-87 4x4 front application (closest extension/compression/ride height dimensions for my set-up). It also has a modified ECE hidden Hitch w/flip-up plate kit. Gets the job done anyway....
06-13-2009, 11:11 AM | #15 |
Very nice!
thanks for the pics and info!!
CHEVY ONLY Last edited by joe231; 06-13-2009 at 11:11 AM. |
06-13-2009, 11:11 AM | #16 |
All the hard work, @ work . . ....
06-13-2009, 04:06 PM | #17 |
Happy to be here
Dude, those Coy's make that truck.You need to get them back on there.
06-13-2009, 05:15 PM | #18 |
Yep, I liked them as well. Once I swap in the DM & raise the ineer fenderwells (that's why I wanted yours), I'll prob get another set. They look good on Trey's Blazer too.....
