06-06-2009, 01:15 AM | #1 |
Disc brake Non-power master cylinder question
I've installed a manual disc brake master cylinder on my '64 C10. Do you have to swap brake pushrods when doing this swap,or is the one on my truck the right length and bore size??
06-06-2009, 09:13 AM | #2 |
It's Better With Nitro
Re: Disc brake Non-power master cylinder question
It kind of depends on the master cylinder. Is the current pedal and rod assembly able to reach the necessary travel of the piston?
06-07-2009, 01:01 AM | #3 |
Resistance is Futile
I used the 'corvette' ms/cyl and bolted it right on. If your pushrod is too long your brakes will drag when driving.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
