My 69 C20 beating a Cummings Diesel with 40 pounds boost.
What do you all think
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
Green club
Re: My 69 C20 beating a Cummings Diesel with 40 pounds boost.
Awesome, what did you end up running?
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
17.33. not too fast i know but a heavy truck
Six in a row makes it go...
![]() Join Date: Mar 2009
So what's in your C20? Must be good to get the pressurized diesel off the line...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
That looked cool, but I hardly doubt that your truck running a 17.33 will beat a 40psi turbo truck I definetly do not agree that other truck was boosting anywhere near 40 psi maybe 4-6 pounds if not the driver cant drive for crap. Here are some examples of truck with 40 psi.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
![]() Join Date: Jan 2008
I agree with Big Al.
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
He did say at the end of the race that his clutch was slipping, but eh. . who am i to complain i was happy to take a win
Rottenwood Garage Member
yep........no way no how......but take the win anyway you can get it!!!!!!!!!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
Devil Pup,
whice race track is that? |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
A win is a win. Congradulations!! Seeing how there are same diesel drag races on this thread, this is one of my favorites!!
![]() WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#13 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I speak from personal experience having a string of hot rod diesel trucks in my life. I pulled trailers everyday with my trucks running these kinds of boost numbers. Remember, black smoke like seen in those videos is overfueling. It doesn't necessarily have any real connection with boost numbers.
#14 | |
![]() Join Date: Nov 2007
#15 |
Ya know, in that vein, a lot of fellas really turn the fuel up on these things and put the turbo way out of it's efficiency range. For instance, the HX35 on my Cummins truck really became inefficient around 35 pounds of boost. It would make more, but it also made lots of heat. It sounds impressive to turn a turbo into the stratosphere, but it's a bad idea. A turbo upgrade is in order at that point, but very costly.
We also get a lot of guys around here that add massive fuel through boxes, grinding the plate, or adjusting the fuel screw (depending on pump type), but never buy a pyrometer to keep track of EGT. Those guys learn an expensive lesson pretty quick. And, when dealing with Cummins engines, lessons are expensive indeed. The fellow above stated that the Cummins guy said his clutch was slipping. That is very common when you really step on one of these things with adding torque. A good Southbend upgrade clutch will run between 1000 and 1500 just for parts alone. That's why so many diesel guys are running around with slipping clutches. They don't want to pay to play and do it right.
#16 |
That truck could had been boosting 100 pounds but still got smoked by a 17.33?
We have so SERIOUS diesel power machines downhere running mid 10's and driven daily and my point was that the other truck was a pig.
#17 |
so does that mean when you see a diesel truck smoking like that..its really running way overfueled?
and that even when you turn the boost up etc, the truck should still run clean? i know a little smoke from like 1000 through 1800 rpm is normal..but beyond that if it is smoking it is improperly tuned?
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
#18 |
No not necessarily. Smoke right off the line is unburnt fuel(very common) but once you get the turbo lit is should clean it up. So if the truck keeps smoking then yes its overfueled. Of course this varies from truck to truck, the diesel drag trucks throw everything they can at them, but your common street truck it shouldnt
#19 |
Exactly.
When you whack it at low rpm, it will blow black smoke. As you watch the boost gauge climb and hear the turbo build, the smoke should clear up almost completely. At full boost, if it still is smoking, you are dumping way too much fuel into the system. Too much fuel under full boost will dramatically increase EGT.
#20 |
#21 |
lol ya its SIR
