Post Whore
![]() Join Date: Feb 2000
Pulling cab, country style! Pics Fixed!
Big trucks call for creativeness, i.e. using haybales to get A-frame up high enough to lift cab off frame. I thought about pulling the wheels but I was going to have to be able to push the frame out from under the A-frame and thought it would be easier to just leave the wheels on.
I will try to attach the photos in a response below.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 01-02-2003 at 12:19 PM. |
Almost Satisfied
![]() Join Date: Mar 2002
Wow that must be a big 454 your putting in there if you have to remove the cab!!
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Post Whore
Guess I will post one more pics of my ugly self with my beautiful truck.
Below.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 01-02-2003 at 12:17 PM. |
Post Whore
Figured life would be alot easier getting everything lined up and bolted back together with the cab off. There's also a little rust that I'm gonna get welded up while the cab's off. What fun!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Fabricate till you "puke"
Wow, thats wild! to think about it tho......those hay bales are packed pretty d@mn tight
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
![]() Join Date: Oct 2001
Sorry but all I see is sqaures with red Xs!
Things happen for a reason! |
I see the pics, but got red x s on the T case pics....
Post Whore
Hmmm, I can see them if I use Netscape, but if I use Internet Explorer, I can't see them.
Gotta Startem Early
I do not have netscape, guess I will have to imagine.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
Post Whore
See if this works
Post Whore
2nd photo
Post Whore
3rd
#13 |
Koooool!!! Bolt the motor in, a seat and some lights and you're good to go. looks like fun. So does that mean you're finally getting the 454 in the beast??
Brandon |
#14 |
Post Whore
Soon, I'm waiting on a coupler shaft that goes inside of the adapter between the Rockwell transfer case and the SM465 tranny - a couple board members may have that part but they haven't been able to pull the part yet to see if they are in good shape - if anyone has that part - please let me know. The 454 just needs have the rear main seal replaced and buttoned up and it's good to go. I'm pretty excited!
#15 |
Bloo
good idea!!! that awfully close to my country style, when we took mine off we hooked a come along to the tere-poles in the tobacco barn and cranked it up, then pulled the frame out with my dads truck and then sit the cab down on the ground, hooked up the tractor to our strap and picked it up and moved it outside the barn
#16 |
My other Love
I had to buy 2 cases of beer for friends to get my cab off the 77. That looks like a nice big shop you have there. I have to contend with my lean to a tarp and a propane heater
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
