Old 06-06-2009, 03:50 PM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
71 K10 Rear Leaf Spring/bushing removal?
Just wondering how the heck you get the bolts out to take out rear leaf spring packs and bushings to replace the bushings.
Had my impact on them and a big hammer and majority wont budge. We got one end to come out and the bushing has us confused as far as removal. Does it need to be hydraulically pressed out or what. Also, do we need to apply heat to the bolts to get them out?
Let me know thanks guys!
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 06-06-2009, 04:03 PM   #2
gator2511
gator2511's Avatar
Re: 71 K10 Raer Leaf Spring/bushing removal?
I had to burn the bushings out with a propane torch. Its the easiest way. Then you can get the bolts out by wrenching or in some cases cutting then off. Its not a easy or fun job.
gator2511 is offline   Reply With Quote
Old 06-06-2009, 04:07 PM   #3
ProStreet83C10
Drag Racer
so you burnt out the bushings BEFORE you took the springs off their mounts?
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 06-06-2009, 06:25 PM   #4
cdowns
cdowns's Avatar
the bolts are fused to the rubber bushings with rust and 40years of crap// if yuo heat the bolts up it should aid in breaking them free of the rubber then when the springs are off the truck burn the bushings out
Old 06-06-2009, 09:15 PM   #5
gator2511
gator2511's Avatar
Re: 71 K10 Rear Leaf Spring/bushing removal?
I burned enough of the bushing rubber to loosen the bolts up. If you use a propane torch and limit the heat you will be ok. Then drive the bolts out and remove the springs and finish burning out the rubber. I beat on the bolts on mine until my arms gave out but when I hit the rubber with heat they gave up quickly.
Old 06-07-2009, 10:52 AM   #6
1987_3/4ton_chevy
Cowboy Up
got one side off but the other side is being a little B****!
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 06-07-2009, 11:12 AM   #7
gator2511
gator2511's Avatar
Keep on burning and beating. I had to cut one nut off. It wouldn't come off any other way. Like my stockbroker said as I was losing my money "You can't be faint of heart and do this stuff" I fired him!
Old 06-09-2009, 11:52 AM   #8
1987_3/4ton_chevy
Cowboy Up
well guys, i used a cutting torch to get the bolt red hot and bang... they came out! Got the new bushings and bolt on and the leaf springs are back in place just gotta use the inpact. I figured, since i just get the rear bushings... why not do the front right?????
Chris Cary
Old 06-09-2009, 03:43 PM   #9
gator2511
gator2511's Avatar
Talking Re: 71 K10 Rear Leaf Spring/bushing removal?
You are a very sick man and should be institutionalised.
Old 06-10-2009, 01:29 PM   #10
1987_3/4ton_chevy
Cowboy Up
what gator2511????
Chris Cary
Old 06-10-2009, 05:11 PM   #11
gator2511
gator2511's Avatar
Just goofing around with you. After the hard time with the rear bushings the last thing I would look forward to is doing the fronts. Come to think I did all mine at one time too!
Old 06-10-2009, 10:11 PM   #12
1987_3/4ton_chevy
Cowboy Up
oh lol ok, sorry about that dude... anyways, i figured why not do them all, ya know
Chris Cary
