Old Skool Club
![]() Join Date: Jun 2001
I have been having problems with the HEI in my 350. I replaced the module a year ago, then about 2 months ago, and now, I believe it is bad, again. So, let's move on past the diagnosis stage.
I have searched the board for specific info related to WHICH HEI to use, i.e., truck, car, Corvette, etc. I am willing to guess that a '78-79 Vette small block (it's all the had) HEI would be a good choice. However, I see that I should also try Jegs, Summitt Racing, etc. MSD makes a killer module, but I'm at the point that I don't trust the basic distrubutor, i.e., the bushings, reluctor, etc. I don't really believe the reluctor would go bad, but I have changed everything in the distributor that can be removed and replaced without pulling the unit from the engine. I am giving up on this one. So, does anyone have any knowledge about WHICH year HEI to use, and would a 'Vette HEI be any better than a truck or car unit? I know to stay away from the ESC units, which I believe were installed beginning in '80. So, from '75 to '79, does any one unit have a better performance capability than another?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Ain't we cute?
I for one have never heard of any year or model being better than any other. I'd get a solid unit and put Pertronix, MSD, or Accel hi-per cap/rotor/coil/module on it. There's several like that on ebay right now. I think a recent trip to 5k RPMs just cooked my module b/c now I have a miss.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES! FOR SALE $3900 ![]() |
I don't think the distributrors are any different. If you are having problems with the factory modules, you have something wrong elsewhere. as long as the distributor isn't visibly cracked or broken, and the shaft doesn't have any side to side play, there is no reason to replace it.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Old Skool Club
Thanx. Been looking on the 'net, and find interesting info. Like AutoZone, O'Reilly's and CarParts.com all have same distributor part number (30-1895) with different pricing. Ranges from $99.95 to $156.99. So, went to Jeg's - blueprinted Accel for $138.99 or Accel Performance Replacement for $139.99. Summitt has their blueprinted distributor priced at $149.95. NAPA (in my town) has rebuilds for $124.95. Jegs are priced without cores. The 'Zone, O'Reilly's and Advance are priced with cores.
But it looks like it doesn't matter...I requested info both for a '79 Vette L48 and L82, as well as a 75 Chevy truck 350. No difference in data. Now, as far as replacement parts go, distributors seem to be standardized. I do know that it matters which vacuum advance it needs, with some (like the '79 Vette) having a different point at which it reaches total advance, compared to the one the truck uses....at least as far as NAPA is concerned. I doubt seriously if anyone else really knows or cares. But, my distributor needs a complete overhaul, mechanically for sure.
