Old 06-06-2009, 08:17 PM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
steering wheel pulls in... HELP!
ok heres whats happening is if you sit in the truck you can pul the wheel towards you like you are pulling the shaft out of it ....On the hood side it seems to be loose above where the spring and washers is on the shaft...this thing sat in the wood for 5 year before last month when I dragged it out to start running it again...... any help to tight'n it up would be great I have a tilt I wanna put in it just need to fix the broken turn signal lever on it..s really can I fix this one quick like or should I just suck it up and change it....Oh it's an auto on the col
thanx
Jeff
Hottrucks is offline   Reply With Quote
Old 06-06-2009, 08:23 PM   #2
dan42
dan42's Avatar
Re: steering wheel pulls in... HELP!
It's probably the bearings - to fix it, you have to pull the column and put in new bearings - not that hard. I have to do that with my '70, it's doing the same thing, but I'm lazy. There should be a FAQ somewhere, or get the shop manual, it's got a got step-by-step in it.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 06-06-2009, 08:51 PM   #3
Hottrucks
Hottrucks's Avatar
I was a fraid someone would say that..I guess it's time for the tilt anyway and chance omeone has the link to the FAQ to rebuild?? I never have any luck with search...I tried before I started this post
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 06-06-2009, 08:51 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
why not install the tilt, and remove the sirn signal lever from the non tilt?
Old 06-06-2009, 10:59 PM   #5
cdowns
cdowns's Avatar
i think there may be a nut under the steering wheel above the top bearing but you may need to move the turnsignal switch to get at it to try and tighten it to remove some slop and shaft movement
Old 06-06-2009, 11:53 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I would check the clearance on the lower bearing (where the spring is) If I remember correctly there is supposed to be 1/2" from the top of the washer to the bottom of the bearing. That was what was wrong with the '72 GMC I built last year, it had about 1". Adjustment instructions are in the Chassis Service Manual.
LockDoc
Leon
Old 06-07-2009, 07:12 AM   #7
Hottrucks
Hottrucks's Avatar
this is my plan but I'm lazy I'm still working out small thigs like caontrol arm bushing the rest of he body panels...ahhhhh I'll put it on the list
Thanx
Jeff
Old 06-07-2009, 08:06 AM   #8
Todd Hepler
Rottenwood Garage Member
Todd Hepler's Avatar
I had this problem with my 72. Someone had changed it over from a 3 speed to a automatic in the past and half-assed the job. Dont even ask about the hole in the floor...
I rebuilt my column a few weeks ago and found that the shaft would slip out because there was a gap between the end bearing and the clamp for the u-joint. I put a hose clamp on it to keep from moving out - now the turn signal disengager works! I have no idea if the factory spec requires another part to reduce this play - I had about 2" of gap between the bearing and the clamp.
Godd luck!
Todd
Todd Hepler is offline   Reply With Quote
Old 06-07-2009, 08:23 AM   #9
RustyParts
RustyParts's Avatar
At the end of the steering column opposite the steering wheel, there is a washer and spring with a locking sleeve, chances are the sleeve has loosened and let the spring back away from the bearing. These pieces place preload on the column bearing keeping everything tight.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 06-07-2009, 08:33 AM   #10
RustyParts
RustyParts's Avatar
Here's an exploded view of the parts I was referring to in the previous post.
Items 40 thru 43. Good luck.
Old 06-07-2009, 08:52 AM   #11
Todd Hepler
Exactly whats missing on mine - thanks for the exploded view
Todd
Old 06-07-2009, 11:32 AM   #12
Hottrucks
Hottrucks's Avatar
my issue is in the 40 - 42 area it's like the spring isn't keeping things tight...it's pretty rusty I wounder if I lubbed it up if I could give some love and push that bearing back up the shaft..maybe it's just stuck on the rust??
any chance of that working?
it's not loose side to side just up and down the shaft??
Old 06-07-2009, 11:39 AM   #13
LockDoc
LockDoc's Avatar
The only way to tighten it up is to adjust it as suggested.
LockDoc
Leon
