p p pullin'
Hi perf 8 bolt rotors....
For a 3/4 ton 4x4.....1985
There are lots of brake kits for the six bolt pattern, but how about the 8 bolt? I want to get some good rotors and Hawk pads.
doug |
Low & Fast!
Re: Hi perf 8 bolt rotors....
Anyone?
Resident of Here
Here are some from Summit.
http://store.summitracing.com/egnsea...115+4294859634 Before getting better front discs, you may want to get rear discs, then if that isnt good enough get better rotors.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() Last edited by thirdstreettito; 06-07-2009 at 08:57 AM. |
#4 | |
Happy to be here
![]() Join Date: Mar 2000
If you have already reconditioned your brake system and it still doesn't perform to your satisfaction there are some options. Before you go further, you should consider replacing the front brake flex line. These are prone to balloon after years of service and will diminish your brake pressure. Braided stainless lines are the ultimate, but new rubber lines will be an improvement. Take a look at what Praise Dyno Brakes has to offer- LINK I have not used their product specifically, but have friends that have. They were very impressed with the improved performance in braking ability. Another option is Applied Rotor Technology- LINK who I have used. I had great results from this companies product, and fantastic customer service. Do some research on the cost of rear disc conversions. If your after ultimate stopping power it probably the way to go. If you want to improve your drum brakes, consider a set of Cryogenic treated performance shoes as a more economical option. ![]()
p p pullin'
Thanks for the replies.....I tow an 8500lb boat and my current rotors are a little wee bit warped and I want to replace them with something better than stock replacement....I put a set of Hawk pads on my old '95 Sub I used to have and it made a noticeable improvement over stock and I was satisfied with the braking performance. Id like to put on some good rotors and pads on this truck. The rear drums on these things are huge, Id like to put on some hi perf rear shoes if there is such a thing......the new flex lines are a good idea, braided steel, even better!....doug
doug |
Happy to be here
Look at Praise and ART for premium upgrades on pads and rotors. Do some research on the cryogenic treating. You will be impressed.
I can vouch for the viability of its success. It makes a huge difference in rotor life and prevents warping.
#7 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
p p pullin'
can you send some websites my way??......all I can seem to find are ones for the 6 bolt set ups
doug |
#9 | |
p p pullin'
here's the racecar.....I love that car
doug |
Ruff Stuff Specialties has the caliper brackets and they also sell them on ebay for about $55 shipped. You just use a set of front calipers and rotors from a dana 44. In total a complete setup will cost you less than $200. This is the setup I am running on my 82 and it will stop on a dime with about 10,000 lb on my trailer.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Happy to be here
Ok, you already have the scoop in cryo-treating. I hear it makes a huge difference on longevity with rear gears as well as tranny sets.
I had a friend run the Praise Dyno pads, rotors, and shoes on his F-250 LWB CC and was amazed at the longevity. Even when the pads wore out, the rotors still looked new. He scuffed them with sand paper to get the glazing off, and never turned them.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-07-2009 at 05:40 PM. |
#12 | |
p p pullin'
doug |
#13 |
I dont have an e brake any more because I used the front calipers and rotors from a 75 k20 but if you use Cadillac rear calipers (not sure what year) you can retain your e brake and yes the stock prop valve is ok
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 Last edited by ghettoluxury; 06-08-2009 at 07:20 AM. |
#14 |
p p pullin'
I'll shoot them an email....thanks!
doug |
#15 |
Happy to be here
Here's another option for rear discs- Blackbirds-LINK
