PIMPING RIDES
Heeeeeeeeeeeeeeeeeelp
in this pic if you look at the passenger tire .it is leaning in at the top .i have the same problem.how do you fix it
1964 CHEVY 1/2 C/10 FLEET ![]() 1981 CHEVY 1/2 C/10 FLEET ![]() 1995 DODGE 1500 V6 FLEET ![]() EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
Re: Heeeeeeeeeeeeeeeeeelp
I think what Chevy did in the was use shims on the upper control arm. That's a lot of camber on that truck in the pic. It's obviously created by how low the truck is and I don't know how safe it is to shove a ton of shims in there to straighten it out. There were no more than a quarter inch of shims in either side of mine from the factory.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
1961 crewcab
alot of times stuff like that will straighten up at ride hieght,I think the best way is to get custom control arms that are designed to work with the different angles of a radically lowered suspension.
yeh if the ball joints are in good shape go ahead and shim it out should be allright.check the lower a-arm bushings too they may be warn a little to much.just my two cents.
just need an alignment....
![]() ![]() Last edited by joe231; 06-07-2009 at 07:40 PM. |
![]() Join Date: Nov 2007
Hey Bigpimp,
Yea, that is a big negative camber. As mentioned, if bushings and ball joints are in good shape camber is adjusted using equal shims front and back on the upper A-arm attachments. You can measure with one of those plastic magnetic angle gage levels, using a straight bar against the wheels. The spec. is +0 deg. 17 min. of angle, that is pretty much straight up. Negative camber at ride height will tend to induce oversteer in a turn, not good. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
#7 | |
PIMPING RIDES
BigPimp,
Should be room for 1/2" of shims or more. TR
