Old 06-08-2009, 03:08 PM   #1
skillet
skillet's Avatar
Question '89 Suburban trans. pan observation
Anyone else have this problem with their '89 suburban - when I just want to do a simple transmission fluid change, I can't remove the trans. pan without first removing a crossmember support that the trans. sits on. And of course I first have to support the trans. before I can remove the cross member. I have tried each time to wiggle the back(aft) edge of the trans. pan past the cross member, but always end up removing the cross member to get it out of the way. Is this what everyone else has to do or is it just me? Thanks for any insight.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 06-08-2009, 09:04 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: '89 Suburban trans. pan observation
I think you have a 700? I know my 350 was hard to get to but I never had to pull the member out.
tvblazer78 is offline   Reply With Quote
Old 06-08-2009, 09:07 PM   #3
tractor1963
Ive got an '89 with 700r4,I changed mine right after I got it,it was a pain to get out but,I didnt have to remove the crossmember.Is yours a 4wd?Mines a 2wd.
tractor1963 is offline   Reply With Quote
Old 06-08-2009, 09:41 PM   #4
WarBeard
WarBeard's Avatar
Pull it out once and install a drain plug.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 06-09-2009, 12:36 PM   #5
skillet
skillet's Avatar
It's a 700 r4 and a 2wd. Maybe I'm just missing something, just seems like they could have designed it just a little different - it wouldn't have taken much, maybe a quarter of an inch. And I was wondering if most get their trans. rebuilt or just buy a rebuilt unit?
Old 06-09-2009, 12:44 PM   #6
babyJay
Arrived on a Pale Horse
babyJay's Avatar
I have not recently tried this but I used to work in the quick lube industry about 15 yrs ago. It was very common then to have to remove x-members on 700R equipped trucks to remove the pan and get to the filter. S-10's were the most common that come to mind. I can't remember if the fullsize trux were the same way.
We always used to place a standard bottle jack on the underside of the tail shaft. WARNING: If it's 4WD, do not place it on the bottom side of the transfer case. With enough jacking the head of the jack will go right through the aluminum case of the TC with no problem and then you will be hosed. Lube flowing everywhere and you'll have to replace it. JB Weld wont fix it.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-24-2009, 09:30 PM   #7
clinebarger
Always use a wood block between the tranny and the jack. Doesnt tend to break things as often
clinebarger is offline   Reply With Quote
