06-08-2009, 09:34 PM | #1 |
Windshield wiper removal
So, I'm trying to get this thing off..and like most things on this truck it's giving me grief. I can see a little clip on the under side of the wiper near the (joint?) and I push up or pull down on the clip and nothing happens. Any other advice or tricks?
06-08-2009, 10:18 PM | #2 |
Junior Member
Re: Windshield wiper removal
Try this, it might work if they are not stuck together by rust.
With a small screwdriver or hook pull on the small spring clip while wiggling and pulling on the arm. I have had to us another screw driver to gently pry. Hope this helps. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-09-2009, 04:49 AM | #3 |
There is a tool available at most parts stores that works pretty well. I got mine in the "Help" section of the store.
Otherwise, I have had to use a large screw driver to pry them off before getting the tool. The problem with prying them off with a screw driver is that the cowl can be bent and the paint can be damaged. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
