Old 06-08-2009, 09:42 PM   #1
mleeb
mleeb's Avatar
Unhappy Wrong Kickdown Cable Help?
I recently ordered a universal throttle cable and an 700r4 kickdown cable from Lokar to replace my current setup. I thought I had an 700R4 trans...
I think I ordered the wrong kickdown cable ... the TV cable tube that slips into transmission is smaller than the Lokar 700R4 kickdown I purchased.
Do I have a different transmission than I thought?(700R4)
Do I have an 4L60?
Are KD cables different from the 700r4 to 4L60?
Thanks for any help...
71 Chevy C-20 Fleetside
Stock 402 BB-Summit Headers-700R4 Trans
Dual 40 series flowmaster w/ H pipe
Edelbrock 2161 intake & 1411 Carb
mleeb is offline   Reply With Quote
Old 06-08-2009, 11:02 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Wrong Kickdown Cable Help?
Any chance the trans could be a 200r4? I don't really know the differences in them, if there are any. Anyways, this will get your post back to the top..
LockDoc
Leon
Old 06-08-2009, 11:14 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
did you tell them it was an overdrive? If you just said kickdown cable, it's probably for a 3 speed. they were called TV cables on the 4 speeds.
Old 06-08-2009, 11:21 PM   #4
mleeb
mleeb's Avatar
Upon further inspection I still think it may be an 700R4.
The serial number in passenger side corner is 4YK147BT anh housing hax MD8 on bell housing...from serial number its a 1984 model
any clues what is the right kick down cable?
Yeah it's an overdrive...
Do I need an Lokar TV cable for an 700r4?
Old 06-08-2009, 11:31 PM   #5
mleeb
mleeb's Avatar
The part number I bought is :
KDP-2700HT Polished Hi-Tech 700-R4 Kickdown Kit
Old 06-08-2009, 11:33 PM   #6
Longhorn Man
you considered a GM part?
Old 06-09-2009, 02:10 AM   #7
mleeb
mleeb's Avatar
Yeah... I'm thinking I may just modify existing gm tv cable to fit I lokar bracket ...
Thanks for your help!!
Old 06-10-2009, 04:40 PM   #8
mleeb
mleeb's Avatar
[IMG][/IMG]
Here is a pic of the existing GM part and the 700r4 Lokar part I bought...
I just cut GM part to fir Lokar braket but still curious what type trans TV do I have...
Old 06-11-2009, 06:49 AM   #9
rlm316
rlm316's Avatar
Does it have a vacuum modulator? 700r4 has no modulator, 200r4 should have an extra set of bolt flanges at the top for BOP applications. Take a picture of the trans pan, then someone here can tell you what you have.
rlm316 is offline   Reply With Quote
