Old 06-09-2009, 08:18 AM   #1
konajoe
konajoe's Avatar
Crew Cab rear seating
I'm looking to pick up a 1985 C20 "Bonus Cab" basically it looks like a regular one ton crew cab, tall frame, hydroboost and 14bolt ff etc but it has no rear seat. Does anyone know if the crew cabs use two front bench seats or a Suburban seat for the back seat.
05 1500 Crew Cab
79 K10 Scottsdale
71 K10/Custom
85 K30 CrewCab
72 Camaro
konajoe is offline   Reply With Quote
Old 06-09-2009, 08:30 AM   #2
mainermikeyd
mainermikeyd's Avatar
Re: Crew Cab rear seating
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
Last edited by N2TRUX; 06-09-2009 at 09:44 AM. Reason: This is not a wanted to buy. Please don't make it one.
mainermikeyd is offline   Reply With Quote
Old 06-09-2009, 02:18 PM   #3
lester622
they use a different seat, the mounts on the back are a flat piece that comes off the seat and mounts it to the flat part on the cab right beloow the rear window.
suburban rear seats also will not work as there a split up seat and mount on a flat floor where the crew cab truck does not have a flat floor.
lester622 is offline   Reply With Quote
Old 06-10-2009, 10:30 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The rear would use the same seat as the front of a regular cab.
BUT, The front and rear seats are the same. The fronts are non tilting because they are mounted in a different hole than the rear and have 2 bolts. With the tilt pieces you could make it tilt.
BTW, Bonus Cab trucks never had seats mounted that is what makes it different than a 3+3.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-11-2009, 01:28 AM   #5
pig rig
pig rig's Avatar
thats what I was going to say
bonus cab = plane jane
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 06-11-2009, 09:07 AM   #6
konajoe
konajoe's Avatar
Thanks for the info guys
True
The truck is listed as a 3/4 ton but yet all the frame, suspension, and drivetrain components are a one ton. I wonder why GM did that? The truck does have a/c and power windows so it's not a work truck stripped model.
05 1500 Crew Cab
79 K10 Scottsdale
71 K10/Custom
85 K30 CrewCab
72 Camaro
Old 06-11-2009, 09:46 AM   #7
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Huh plain Jane, tell that to my 89 Bonus cab with Power d/l and windows including electric back glass, rear seat that folds into a bed , overhead console that looks like it was borrowed from an airplane,tilt, cruise, Dana 80 rear with front and rear sway bars. granted some of that stuff was added at the dealer but it was still optioned pretty well as it rolled off the line. The only thing missing was a factory back seat.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 06-12-2009, 12:20 AM   #8
pig rig
pig rig's Avatar
Josh
maybe so but a lot of the bonus cabs I've had were orderd by contracters and about the only option they have is AM radio if that
Old 06-12-2009, 09:13 PM   #9
truckfan
truckfan's Avatar
Josh
western hauler and other conversion companies used to order "custom deluxe" (love the term since neither "custom" nor "deluxe") w/o back seats so they could put all their "van-like" interior into them along w/ a folding rear seat. lots of these trucks also had single headlights--a'la custom deluxe
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 06-12-2009, 11:16 PM   #10
LEEVON
Moderator
LEEVON's Avatar
rear seat frames are exactly the same as front with different mounting brackets. If you can find the brackets only and a front seat you're set.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 06-13-2009, 10:06 AM   #11
Captkaos
Captkaos's Avatar
As truckfan stated Conversion companies ordered bonus cabs of any trim level mostly base trim because they were going to gut the truck anyway and use their own parts.
If you need a back seat for one, just get the front seat of a regular cab pickup and then acquire the brackets. You could probably fab some up also. Same goes for the seatbelts for the rear...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 06-13-2009, 10:06 PM   #12
pig rig
pig rig's Avatar
monday I'm going to pull my seats out of my crew cab so I can clean the carpet Ill pull the brackets off my rear seat and get a picture and post it up
