Old 06-09-2009, 02:13 PM   #1
cjohns
cjohns's Avatar
rear axle bearing ??
can someone give me some info on the outside axle bearing...are they pressed on to the axle??I have to replace the outer seal when I do the brakes but I haven't ever done a Chevy truck.So any tips would be great!!(my truck is just a C10)Clark.
cjohns is offline   Reply With Quote
Old 06-09-2009, 02:47 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: rear axle bearing ??
No, the axle bearing is pressed into the rearend housing. You will remove the axle to access the seal, but the bearing can be left alone. Once the axle is removed, the seal is right there to be pried out and replaced.
Old 06-09-2009, 05:46 PM   #3
cjohns
cjohns's Avatar
Thanks!!That's what I was hoping for!
Old 06-09-2009, 05:53 PM   #4
cparman
sharp as a marble
If you are just doing the rear brakes, you can leave the axle bearings and seals alone. IF you have a leaking rear axle seal, I would suggest replacing both sides at the same time.
cparman is offline   Reply With Quote
Old 06-09-2009, 05:57 PM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
I have to replace my oil seals and had the same question over in this thread...http://67-72chevytrucks.com/vboard/s...d.php?t=347621
So if I want to replace my bearings too, would I need to have someone remove the old and press in the new??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-09-2009, 06:16 PM   #6
Tx Firefighter
No. You need the special puller to remove the old bearings from the housing. Then, you can knock the new bearings into place with an appropriate sized piece of pipe or even a very blunt punch and hammer.
Old 06-09-2009, 06:21 PM   #7
cparman
sharp as a marble
this will be a bit long. To replace the rear wheel bearings on our trucks, you will need to remove the rear axles. To do this, you need to:
remove the rear end cover
have a catch pan under the cover to keep from making a mess.
turn the rear end carrier around until you see a small bolt on the right side of the carrier 5/16 head 6 point bolt
remove this bolt
carefully push the center pin out of the carrier from top to bottom
DO NOT MOVE THE CARRIER
push the axles in a bit now and the c-clips will drop out
remove them, and pull the axles out of the housing
if you have borrowed a slide hammer type puller with the correct adapter, slip it inside the bearing, and pull the bearings
IF YOU DO NOT HAVE A SLIDE HAMMER PULLER
home depot sells rebar. go buy a piece that is about a foot longer than your rear end, and use it as a punch to knock out the bearings.
I usually pack some grease in the new bearings, and coat the seal a little bit as well.
hope this helps
Old 06-09-2009, 06:37 PM   #8
68gmsee
Active Member
68gmsee's Avatar
fyi: If you have a Dana 44 or 60 differential you don't need a bearing puller.
More than likely you don't, but I thought I'd throw that in there.
68gmsee is offline   Reply With Quote
