Old 06-09-2009, 03:44 PM   #1
Zonaman
Zonaman's Avatar
Front End Question
Are the spindles and hubs from a six lug, '69, C10 interchangeable with a C20 same year?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 06-09-2009, 04:23 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Front End Question
Not without changing the ball joints too.
Old 06-09-2009, 04:48 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I thought the lower arms were different. The ball joint is larger in diameter and won't fit into a 1/2 ton arm.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-09-2009, 05:03 PM   #4
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
I believe you are correct. swapping to a 1/2 ton LCA may solve that, and changing the upper balljoint.
why not go disc though?
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 06-09-2009, 05:27 PM   #5
70rs/ss
70rs/ss's Avatar
Other way around 1/2 and 3/4 ton A-arms are the same, the LOWER BALL JOINT is bigger (the shaft, not the part that presses into the A-arm) on the 3/4ton, thus if going to 3/4 ton spindle, use the 1/2 ton A-arms and swap the lower BJ to 3/4 tons and you are golden! I second the why not go discs!?
70rs/ss is offline   Reply With Quote
Old 06-09-2009, 05:48 PM   #6
chevy_mike
chevy_mike's Avatar
I beg to differer. When I was looking to do a cheap disc brake upgrade and use spindles (which I bought) from a 88-98 LD 3/4 ton (per instructions found on this site), it stated you had to change the lower A-arms to 3/4 ton, so you could use the late model 3/4 ton ball joint and spindles. I went to NAPA and compared the early 1/2 ton, 3/4 ton and late model 3/4 ton. The early 1/2 ton ball joint size (the part that presses into the arm) was noticeably smaller and mic'ed out smaller. I didn't save the numbers so I don't recall them but they were different between the 1/2 and 3/4 ton sizes. The lower A-arms are different.
