Old 06-09-2009, 05:10 PM   #1
rlcasey75
BoomerSchooner75
Dirt in My RADIATOR...
ok i flushed radiator and i noticed it was brown. i first thought that it was rust and thought to myself oh ^%#$ here we go with this but i decided to see what it felted like so i grabbed it and was confused because it was dirt. how does dirt get in there and how do i get it all out. Can it pose any major problems.
rlcasey75 is offline   Reply With Quote
Old 06-09-2009, 05:19 PM   #2
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: Dirt in My RADIATOR...
hmm..... well the only way i can think of dirt finding its way into the cooling system of a vehicle is Sabatooge! (forgive spelling) as in a person did it.
One other way would be you went mudding the truck may have got stuck wich led to overheating, the overflow tube was dragging in the mud and as the system cooled down it sucked muddy water back through the radiator due to the vacume of the displaced coolant .
a little detail on the truck would help.
But if it were my guess i would say your water pump may be deteriorating, gasket particles, possibly some old raidiator repair junk freed up, or just very fine rust particles.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 06-09-2009, 05:48 PM   #3
rlcasey75
BoomerSchooner75
it has a 350sb with a th350 tranny. it has 2 electric fans on the radiator. the over flow for the radiator was not on it when i got it but i have replaced it. i do know that the PO was in the process of converting in to a mud bogger.
Old 06-09-2009, 06:07 PM   #4
sperz1
sperz1's Avatar
Are you running green coolant or Dexcool (the devil)
sperz1 is offline   Reply With Quote
Old 06-09-2009, 06:24 PM   #5
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I have seen radiators with coffee in them. You read that right coffee! It was one of those "at home quick fixes" for leaks. My wife's 01 Jeep had that when we got it. I was amazed to see that people still do that sort of thing. I did about 4 good full flushes and got most of it. But then the water pump impellers had rotted away and the radiator started to leak. So, now all that is new and it seems to be good.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 06-09-2009, 07:14 PM   #6
AceX
>130dB Moderator
AceX's Avatar
I doubt its actually dirt, probably rust of some sort. I have the same thing in mine. It's somewhere on the passenger side of the motor, probably in the head, but I don't really worry too much about it. A good couple system flushes should set you.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
