New Cab Floor
This is why its being replaced, along with previous owner repair work that just wasn't up to snuff.
Last pic is floor cut out from cab.
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
Re: New Cab Floor
Stripping some of the cab to see what kind of nasties are hiding under the paint. And the cab with bracing to keep the original shape/dimensions intact.
We will be replacing the floor with a new one that Tri-Plus makes. It includes the complete underside bracing and supports. We picked it up from TriPro Automotive in NJ. Thanks for the tour John!
go cyclones
Re: New Cab Floor
Thats some crazy bracing, looking good
can I tuck tractor wheels?
Re: New Cab Floor
Good decision to replace the floor. Im planning on doing the same ( I think ) even though mine isn't near this far gone.
My build page.... http://67-72chevytrucks.com/vboard/s...d.php?t=347666 |
Re: New Cab Floor
This is what the rear of the cab looked like after drilling out the spot welds and striping the paint. The PO also welded the floor repairs he did solid to the inside of this. So I replaced it with a piece I made up.
Re: New Cab Floor
Second pic shows new piece tack welded and cleco'ed to the back edge of new floor. I left it long for now, so I can cut it just where needed when fitting the cab corners.
Re: New Cab Floor
Now onto the firewall seam area, as you can see, it needed attention also. I cut out the rotted area and replaced it with a new piece made up on the brake.
Re: New Cab Floor
I had to repair both sides.
Re: New Cab Floor
I epoxy primed the metal before the seam was joined.
Bottom pic is viewed from exterior and shows the plug welds used. At this point I have the rear of the cab temporarily attached to the floor with cleco's, and the front was clamped together until the new front pillars and foot wells were fitted and tack welded in. I should note that the very front edge of the new replacement floor was not formed strait as others have noted. I am referring to the folded edge that spot/plug welds to the bottom of the firewall. I needed to make some relief cuts and hammer/dolly it strait to match. This has been noted by other users of this floor also., but is fairly easily fixed with a little thought. I had some pics showing this but seemed to have lost them :[
Re: New Cab Floor
This is how I determined the height of the cab floor, but i am not going to weld anything solid until the cab corners are fitted with the body lie/crease lining up properly to the door body line/crease.
The replacement rear pillars needed some minor messaging to fit properly. The other pics show the rear door pillar fitted and tacked.
Re: New Cab Floor
Here is a back side view of the rear pillar.
I have lost or erased the front pillar/foot well fitment photos. Here they are completed.
Re: New Cab Floor
The firewall being preped for epoxy.
My son Logan blasting the rest of the cab, he does the dirty work! Notice the PO HEI clearance job lol. We will dolly it smoother before we are done.
#13 |
Re: New Cab Floor
Wow - you guys go to extremes to save cabs. I know of a couple of trucks with cabs in better shape than that sitting out in a field.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
#14 | |
Re: New Cab Floor
#15 |
Re: New Cab Floor
BTW, I forgot to mention, that's really nice work you're doing on that truck. It's fun to see something like that come back to life. Keep us posted!
#16 |
Re: New Cab Floor
Chas, nice work, good to see some progress. Those floors save alot of work. Can I offer some advice?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#17 |
ENGINE BUILDER
Re: New Cab Floor
YOU KRAZY MAN!!!! Very nice work. Most "rust free" trucks I have seen from out west still need rockers and cab corners and footwell work. Western trucks have upper damage from roof caulking that has dried out and allowed water to get in.They rust from the top down. East coast trucks rust from the bottom up.They pretty much all need work.
JIM ZAG |
#18 | |
![]() Join Date: Nov 2003
Re: New Cab Floor
How about shipping some of those cabs from Cali to CT? |
#19 |
Re: New Cab Floor
HOLY SMOKES, you make me feel bad for not using parts with just a little pitting on them, you guys are true restorers out east, Me and plenty of others out west would have give up on that one!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() |
#20 |
Re: New Cab Floor
Its only fair that I give Ebfabman credit for his fine cab repair video! It has certainly made the job easier. Thanks Earl!!
#21 |
Re: New Cab Floor
Anytime....
#22 |
Re: New Cab Floor
Sure.
#23 |
Re: New Cab Floor
Up in post #10, 4th and 5th pic. The 'B' post patch fits great where you have it, but, when you put the rocker on you will have a gap at the lower 'B' post. So you won't have anyway to weld the two together at that point. Also, on the inside the 'B' post patch isn't touching the floorboard, so, if you make an extension on the 'B' post patch panel above those areas, it should drop everything down into alignment and contact. The extension should be all strait bends, nothing complicated. Hope this helps, check out that area when you hang your rocker.
I could be wrong, and I hope I am, but past practice says not. Maybe they fixed this problem since I last worked on that area Nice to watch your work, and seeing your son enjoy it too. Good luck with your truck
#24 |
ENGINE BUILDER
Re: New Cab Floor
I saw a 67 from COLORADO last night at a car cruise and it was all original and I am telling you it had NO RUST in the rockers or footwells!!! He would not sell it to ME!!!!
JIM ZAG |
#25 | |
Re: New Cab Floor
Thanks for the heads up! That is one reason the back of the cab is only attached with cleco's and why the b pillar is only tack welded in, all my measurements and fitting want the b pillar where is is currently, but I didn't like the way it fitted to the floor either. I am rebuilding a door to mount, so I can line up the body lines before doing the rocker or cab corner. I am very anxious to see how everything fits. I can already see the cab corner needs to be bent closer to a 90 degree angle than it was formed. And thanks to the PO lapping new full size/uncut cab corners OVER the existing corner and welding it solid.....it is more of a challenge. But its all good! I love working with metal :] I am having a blast! Logan on the other hand is burnt out on sand blasting for a while lol. chas
