Old 06-10-2009, 01:23 AM   #1
abilityonline
hand brake 68 c-50
the hand brake on my c-50 dump truck isn't braking well. I can tell it is engaging the transmission but not enough to stop the truck on a hill. I'm not positive how to tighten it up. anybody done this before and point me in the right direction?
abilityonline is offline   Reply With Quote
Old 06-10-2009, 11:09 AM   #2
abilityonline
Re: hand brake 68 c-50
bump
Old 06-10-2009, 11:26 AM   #3
fine69
fine69's Avatar
Your probably the only guy here who is driving one.
I dont think i have ever seen a brake setup on one of these.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 06-10-2009, 01:38 PM   #4
Bugsy_malonn
Bugsy_malonn's Avatar
I have one in my bus but not sure what you need to know
71 GMC 1 ton dually tow truck "Cooters tow truck from the Dukes of Hazzard"
1988 chevy 1 ton 4x4
Chevy step van "dont know what to do with it yet LOL"
1940 chrysler
1949 dodge panel rat rod
1989 jeep cherokee
"With a 8 inch lift and a ton of other stuff and two parts jeeps"
Then the wifes van LOL
Bugsy_malonn is offline   Reply With Quote
Old 06-10-2009, 02:11 PM   #5
texanidiot25
Eat My Rust
texanidiot25's Avatar
There's a few guys with one.. Give the thread time.
CG I think had one once... Used it to pull an ancient bush out of his yard, wheelying the truck
texanidiot25 is offline   Reply With Quote
Old 06-10-2009, 03:24 PM   #6
abilityonline
It starts to brake at the very top of extending the hand brake. I'm assuming there has got to be a way to tighten or adjust the linkage/line to make it engage the brake earlier as you lift up on the hand brake
Old 06-10-2009, 03:53 PM   #7
john
member #16
john's Avatar
Does your truck have the E brake handle that is floor mounted and raises to vericle position? If so it should have a rounded knurled knob at the top. You can usually adjust the brake by turning the knob clockwise. If it is is out of adjustment you back the adj. knob all the way off and adjust the brake shoe tighter to the drum, and then you can use the adj. knob again. If you adjust the shoe make sure to keep it centered and not dragging. Chances are you will need new lining if out of adjustment.
john is offline   Reply With Quote
Old 06-10-2009, 04:02 PM   #8
abilityonline
It has an e brake floor mounted that pulls straight up. There is very little resistance and I'm guessing needs to be tightened. Apparently this is done by turning the knob clockwise? Wow great news. As far as adjusting the shoe I haven't tried to do this nor know how.
Old 06-10-2009, 04:39 PM   #9
john
member #16
john's Avatar
Does it look like this? If not disregard what I said.
Old 06-10-2009, 05:12 PM   #10
abilityonline
that looks right. it's a short connection that runs to the drum
Old 06-11-2009, 01:22 PM   #11
abilityonline
by simply twisting the knob clockwise it tightened up like a charm and works great now. Which is a relief as with heavy loads its great to have when stopped on an incline at a stop light! Thanks for the great help
Old 06-11-2009, 02:46 PM   #12
john
member #16
john's Avatar
Good deal that it worked and you had some adjustment left.
