Old 06-10-2009, 07:03 AM   #1
Beefcake
lost ignition
Hey guys,
quick question.
I complely lost the ignition voltage, at the ignition terminal, on the fuse box.
What feeds the ignition on the fuse box?
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 06-10-2009, 08:34 AM   #2
Beefcake
Re: lost ignition
to be a little more specific. I lost the unfused ignition on the fuse box.
Old 06-10-2009, 08:54 AM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: lost ignition
Beefcake,
check over in the FAQ threads....there's a colored wiring diagram over there that may help....just click on FAQ thread in my signature below and look through there!!...Good luck
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-10-2009, 08:56 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: lost ignition
Follow the wires from the battery...
68gmsee is offline   Reply With Quote
Old 06-10-2009, 11:31 AM   #5
Beefcake
Re: lost ignition
thanks guys. Ill check it out.
