Old 06-10-2009, 10:12 AM   #1
walker
walker's Avatar
installing posi carrier
I have a 67 with a 4.11 posi rear and have wanted higher gears for a while. I found a 3.73 open diff, but would like to keep my posi. How difficult is it to swap in my posi carrier into the open diff. I have had people tell me that they just swapped the carriers using the shims that were on the carrier they were swappin in. What are the chances of doing that? I could also swap the gears into my existing rear axle onto my posi carrier if there is a better chance of success. Let me know if anyone has done this swap.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 06-10-2009, 10:22 AM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: installing posi carrier
Well, my experience with trying to set up my own rearend ended up in me taking it to a shop to get rid of the howling noise! I even had the contact pattern right (or so I thought) and checked the backlash, etc.. I've witnessed said shop swap carriers on their own shop truck (going from open to posi) and had to use a different shim pack. Basically, with changing the gears onto your carrier and existing housing, everything will need to be set up from square 1. Crush sleeve, shims, etc. Are you gonna reuse any bearings? I would say you would be extremely lucky if it just happened to go back together and not make noise.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-10-2009, 11:36 PM   #3
walker
walker's Avatar
Thanks, that was what I needed to know. I think I may just swap in the 3.73 open diffy, then when I have the time to play with it move the other spare 3.73 gears into my original rear end.
Andy,Phx AZ
"23 C-Cab-sold
'70 MG B.-sold
