Old 06-10-2009, 11:19 AM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Unhappy does $50 sound good for a 5 lug coil spring rearend?
does $50 sound good for a 5 lug coil spring rearend? neighbor has one i need to finish my 5 lug conversion..he wants 100 but thats too high to me lol, ima offer him 50 bucks cash and havent figured how ima drag it 1/8 mile across my field to my house lol
can i post wiw if someobdy else is selling it, if not please delete this
John
1999 Toyota Tacoma 4x4
Old 06-10-2009, 11:23 AM   #2
70rs/ss
70rs/ss's Avatar
Re: does $50 sound good for a 5 lug coil spring rearend?
A 5-lug coil sprung rear in a one wheel wonder is worth $100-150 so if you steal it for $50 more power to ya!! It may be a posi, and if so then it is worth $300 or more depending on the ratio. Redneck it, stick it in the trunk of a car it is only 1/8, or get a couple of "BIG" friends to come over and carry it for ya!! Buy beverages, they'll do it, I would!
70rs/ss is offline   Reply With Quote
Old 06-10-2009, 11:29 AM   #3
oldblue1968chevy
lol beverages are out lol
its far nuff away to shoot it with a pellet gun lol
its gota swb bed on it too, bed is SHOT though...has 2 good steel wheels also
its been sittin awhile, should i have to rebuild anything on it?? bearings brakes anything, id like ot be a plug'n play thingn..
John
Old 06-10-2009, 11:34 AM   #4
dammitmitchell
the pollock
dammitmitchell's Avatar
anything with rubber on it
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-10-2009, 11:36 AM   #5
70rs/ss
70rs/ss's Avatar
I would pull the cover and change gear oil and inspect it to be sure no broken teeth or metal chunks in the carrier (this also allows you to ID if it is a posi or not!), also do a rear brake job, $50 and you won't have to worry about them for a while!!
Old 06-10-2009, 11:40 AM   #6
Jim_PA
It probably needs new seals all around. Hopefully no water got in it.
Jim_PA is offline   Reply With Quote
Old 06-10-2009, 03:16 PM   #7
grayw0lf
I'd jump on it for $50.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-10-2009, 11:43 PM   #8
Yullose
I'd be willing to bet the ring gear is rusty.
I've seen rears that sat a long time... where anything above the level of the oil becomes rusty from condensation.
I'd pull the cover and check it before handing over any cashmola.
Yullose is offline   Reply With Quote
Old 06-11-2009, 05:30 AM   #9
jim zag
ENGINE BUILDER
jim zag's Avatar
Sounds like a good deal.
JIM ZAG
jim zag is offline   Reply With Quote
Old 06-11-2009, 09:08 AM   #10
oldblue1968chevy
well its in some briars...if the ring gears rusty...will it have to be replaced, if yet im backing away...
John
Old 06-11-2009, 09:13 AM   #11
70rs/ss
70rs/ss's Avatar
Well yes and no, if the rust has made pits, then yeah because that'll weaken the teeth, but again for a $50 rear, I'd still buy it and run it rust or not, clean it up real good and use, just know somewhere down the line you'll need a set of gears ($150-200) and the labor to have it installed (another $200 or so), but untill then you have a 5-lug rear.
Old 06-11-2009, 10:10 AM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Any idea what year rear end it is? You may be able to swap the axles into your 6 lug axle? Someone correct me if im wrong ...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-11-2009, 10:15 AM   #13
BossHogg69
motor exploder
BossHogg69's Avatar
71/72 5 lug axles will be too long if it's a pre-71 6 lug rear.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-11-2009, 12:20 PM   #14
oldblue1968chevy
well i know its 71 72 chevy rearend lol...may try to talk to him today..man my summer is busy....
work on truck, eat sleep, wake up geton here, find nother part/thing to do wokr on truck....eat....see gf, ride the wheeler, go bed, wake up play on truck find parts money to fix it cause i shorted something out...etc etc
John
Old 06-11-2009, 12:36 PM   #15
Jim_PA
Sounds like a rough life
Old 06-12-2009, 08:01 AM   #16
Value would be based on condition,which we know nothing about.But,if the guy is willing to cut his price in half for you because you don`t have as much as he wants and the rear is something you can slap in and run,then yes it`s worth it.
Old 06-12-2009, 08:04 AM   #17
ginter
ginter's Avatar
If it was my neighbor I would have given him the $100 already.
ginter is offline   Reply With Quote
Old 06-12-2009, 11:39 AM   #18
oldblue1968chevy
i can buy a whole swb truck for 700 lol
ima try to find him today and offer 50$ so i can have another LITTLE project...
John
Old 06-12-2009, 02:35 PM   #19
70short
I can't pick one up at a salvage yard around here for less than $500. with 373's
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
