Leaving the ignition on causes no spark?
Our '57 Chevy has a 235 with the points set-up, well, anyway I moved it late one night and forgot to turn the key to the off position, and unfortunately left it on over night.
![]() If this helps you guys, let's pretend this is a 1960 chevy truck, so it is appropriate in this forum ![]()
1982 K10 SWB 1987 V20 - Sold - Doh! |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Leaving the ignition on causes no spark?
Should just be the points burned. Replace or file whichever route you prefer.
1961 crewcab
points got burned, try using a nail file or piece of sand paper to clean them up, use a matchbook cover to re-gap 'em, and if it still won't go, they are too burned, so just replace them.
1961 crewcab
yea man sounds like your points are burned up...ive done the same on my 64. it does this bc there is constant power running to them...it burns them...i tried filing mine but it didnt help...it may be different for you but hay if filing dont work they dont cost that much...i thank my set was like 5 bucks...and dont forget to set them back right...that will cause them to burn too
Shlong Bed Club
been there, done that, now i run a mallory unilite on my ole 250. now it idles like my 2006
I replaced the coil, circuit breaker, condenser and points, and gapped them tonight. It still has no spark.
I guess the test light comes out now!
1961 crewcab
the voltage relay(?)-the 2X3 square box that the harness hooks into under the hood might be burned up as well, I think that was a problem I had with my modelT (55 chev wiring harness), seemed to remember no spark/wouldn't run, and then a burnt up ignition switch....
changed al that and it worked again. there are some sort of points/breakers inside that box that might have burned up as well. before any thing, double check that you got the pionts installed in the right spot, and that they open up when they should, if you are off, I think you get no spark. |
57 Chevies don't have a circuit breaker in the ignition circuit.
To test the ignition,run a temporary wire from the + battery terminal to the coil + terminal.Then crank the engine.If it runs,the problem is in the wiring.To kill it,just pull the temp wire off.If it stays running,the problem is in the starting circuit or wiring.Which includes the starter solenoid,ignition switch,ballast resister and wiring. Don't leave the +temp wire on for more than 2 minutes-It will burn the points again. Mike. ![]() |
use your test light. put test light on pos side coil, crank engine and see if light goes out or stays on.should stay on if not you have a bad ignition switch, light stays on then go to neg side of coil,test light on that crank engine over test light should flash on and off light stays on you have a problem with your points something not done right.
52 3100 5 window stock for now 56 f100 big back window, 392 hemi-727 48 f1- 326 pontiac 63 c10 swb-big back window-project working on now 2001 custom fatboy harley 1996 ford f250 4x4 lifted 460 5sp 1997 jeep 1996 jeep |
