C-Notch. What is the max drop without it?
Okay guys, I've heard a LOT of different opinions on how far you can drop a truck in the rear without C-Notching the frame. I want to go a 3.5-4/6 Drop but I don't want to touch the frame. I'm okay with having to get the shock relocators and the adjustable panhard bar. So, can I do it? Or can I just go 5??
WTB this ad
Re: C-Notch. What is the max drop without it?
How do you intend to use the truck?
In my experience light to no hauling is fine with a 6" drop and no notch...If you don't mind it bottoming out occasionaly. If you never want it to bottom out for light hauling 5" should put you where you want to be. Heavier hauling?...Probably want to put some bags in there to compensate for the load and keep the axle away from the frame. |
![]() Join Date: May 2008
I went with 6" drop in the rear (4" drop spring and 2" blocks) and have never hauled anything and never seemed to need the c notch.
I had to cut the 2" block in half to go back to a 5" drop to make the truck sit level (not tail dragging look) with the 2 1/2" drop spindles and 2" drop springs in the front.
Mine is chopped, has a clutch, and a big block. |
WORTHLESS CRUISERS
Ive got a six inch drop with no notch. I haul lots of stuff to shows and cruise ins but I never bottom out. Of course you need good shocks and springs.
Scott Hammond Lancaster, SC 1969 Chevy ![]() If you don't live for something, then you'll die for nothing. www.xclusive-images.com ![]() |
Tot Roddin'
As previously posted... about a 6" static drop in the rear without a C-notch is all the farther I would go.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
the boat guy
i have 5" lowering springs in the back of my truck, 1/4" from the bumpstop empty, on the bumpstop if i get in bed. doesnt ride bad empty.
i thionk im going to need a slightly different setup because i just got a under bed fuel cell and my stance is off.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#7 | |
PITbut
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
Do not intend on hauling anything really. Maybe the occasional lawn chair to the drive in movies or something but that would be it. Ive got a 99 GMC Sierra to do the heavy stuff. Thanks for the help guys. Sounds like I'm going to be able to go 6" without any trouble. Much obliged boys much obliged.
#9 | |
PITbut
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've got literally over 100k miles on my truck with 6 inch rear drop springs and no notch. It's fine. I have hauled Honda Goldwings in the bed (really, I'm not kidding) and it will bottom out then.
The secret is to remove those crazy tall stock bump stops. If you leave them in place, you are certainly going to hit all the time. Get some little short bump stops and you are golden.
#11 | |
PITbut
What brand rear springs do you have ? Mine are Early Classic. I once had a set of Eibach rear springs. They were much softer than any I had ever seen.
#13 |
PITbut
Early classic fronts and rears. Now its all bagged and notched. ahah
