Old 06-10-2009, 09:27 PM   #1
Bazooka
Keepin it old school
Bazooka's Avatar
12-bolt Rearend. 3 series or 4 series??
How can I tell if my 12-bolt rearend is a 3 or 4 series? My rear is in bad shape and needs a complete rebuild including ring and pinion.. It has 3:73 gears right now..
Thanks for the help
Bazooka is offline   Reply With Quote
Old 06-10-2009, 11:56 PM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: 12-bolt Rearend. 3 series or 4 series??
I think a 3:73 and up (numerically) is a 4 series, but I'm not a specialist.
Alan's Classic is offline   Reply With Quote
Old 06-11-2009, 06:31 PM   #3
Bazooka
Bazooka's Avatar
Thanks Alan.
This seems to be true from what info I have been able to find online..
Old 06-11-2009, 07:29 PM   #4
198plus
198plus's Avatar
If it's a 373 gear it would be a 3-Series.......3.07 thru 3.90
198plus is offline   Reply With Quote
Old 06-11-2009, 07:52 PM   #5
Bazooka
Bazooka's Avatar
Just curious where you heard this info? Pretty sure this isn't correct. All info I can find online says 3:73 is a 4 series but there is aftermarket 3:73 gears that will fit into a 3 series case.
I hope this isnt true I already ordered my gears
Old 06-11-2009, 08:00 PM   #6
Bazooka
Bazooka's Avatar
Randys Ring and Pinion sight says 3:42 and down (numerically) carriers are the thick gear sets which Im assuming is 3 series. That would make 3:73 and higher (numerically) 4 series.
Old 06-11-2009, 09:24 PM   #7
198plus
198plus's Avatar
A 373 12 bolt......came factory with a 3 series carrier.
12 bolt ED32088 ..............2 series......... 2.73:1 & down
12 bolt 30140PM1.............3 series........3.08:1 to 3.73:1
12 bolt EDB30174............. 4 series....... 3.90:1 & up
Or by measurement:
Old 06-11-2009, 09:46 PM   #8
Bazooka
Bazooka's Avatar
I think what your saying is correct for passenger cars. The passenger car and truck rears are different in that respect right?
Car 3 series 3.90 and down
Truck 3 series 3.42 and down
Truck 4 series 3.73/4.10/4.56... 3.90s were not offered
I just looked at several parts suppliers websites and 3.90 is only offered for passenger cars..
Somebody else want to clear this up??
Old 06-11-2009, 10:10 PM   #9
198plus
198plus's Avatar
I wouldn't think there would be a difference in the car or truck 12 bolts.....I'll try to find out
Old 06-12-2009, 03:20 PM   #10
wild one
Registered.........
wild one's Avatar
The truck twelve bolt IS different than a passenger car twelve bolt - every aspect from the diff cover to drums is different!
The factory truck carriers were offered in either a three or four series with the factory ratios of 3.73 and up are ALL 4 series. The trucks that are 3.42 and lower are 3 series.
The aftermarket DOES offer a 3.73 gear that will work on a 3 series carrier - the ring gear is thicker to account for the extra offset of the carrier.
DO NOT use shims to put a 4 series ring on a 3 series carrier - if any of the bolts happen to back out (due to excessive deflection of the ring gear since it is not securely bolted to the carrier) the results WILL be catastrophic!
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 06-12-2009, 03:38 PM   #11
Tomsriv
Tomsriv's Avatar
Not to hijack the thread, but what different ratios were available on 1/2 and 3/4 ton trucks? I thought most were 3:73.
'65 Chevy shortbed stepside.
Tomsriv is offline   Reply With Quote
Old 06-15-2009, 02:16 AM   #12
wild one
Registered.........
wild one's Avatar
I can only quote the 1/2 ton twelve bolts, ratio's as follows:
3.07, 3.40 or 3.42 (depends on what year 12 bolt you source them from) 3.73, 4.10 or 4.11. those are the only ratio's that I am familar with.
The two most common for 1964 - 1972 are the 3.07 and 3.73's.
You can find the 3.40-3.42's in the mid 70's trucks, mine came in a donor 1975 GMC that I bought for $150.00 and DROVE home!
Popcorn:
