Old 06-10-2009, 09:53 PM   #1
lukbrw
lukbrw's Avatar
Brake light issues
First started off with the right rear turn signal not working.....turned out the complete socket was shot. So I replaced that.
Now with the head lights off, blinkers work and brakes work.
With the head lights on.....blinkers work but the brake lights do not come on. Any ideas? The wiring is not stock. So if there is a way to at least start to figure out how to connect it.
lukbrw is offline   Reply With Quote
Old 06-11-2009, 03:33 PM   #2
Toops
Re: Brake light issues
Try replacing the headlight switch. They tend to wear out and short out the tailights when the headlights are on.
76 Chevy 355 Vortec Heads
Toops is offline   Reply With Quote
Old 06-11-2009, 04:43 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
make sure that there is no short in the harness between the brake light switch and headlights.. ive seen this on a truck with rot
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-11-2009, 07:25 PM   #4
Keith Seymore
Keith Seymore's Avatar
I can't quite tell from your avatar picture: Is it a stepside?
If so, it could be a ground issue.
On my '80 stepper, I used to take the taillight brackets off every spring and repaint them and reinstall with new stainless fasteners. It came with little star washers on the taillight brackets, which were supposed to cut into the paint (which they did) and provide the ground, but since they would get all rusty I would repaint and replace tem. Eventually I had no turn signals and no brakelights.
When I finally figured out what was going on I added a separate ground wire from the light socket down to the frame rail. Problem solved!
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-11-2009, 08:15 PM   #5
silvereagle07
silvereagle07's Avatar
Get a test light, ground it , test both sides of the rear stop lamp with the brake pressed. If the test light lights up on both terminals you have a ground problem.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-12-2009, 07:32 AM   #6
lukbrw
lukbrw's Avatar
yep, it's a step side and the tail lights are out of a gremlin. So completely a home wire job...which was why I'm trying to figure out what goes where. The color of the wires are what ever the previous owner had, so nothing I can compare to stock.
I replaced one socket, the original one was metal and the new one is plastic. So I may need to ground it??? There were two wires going to it, so how do I know what one to ground.
I'll start with the test light also to see if both of the contacts light up like you said. Just wierd when everything works except at with the headlights on.
Old 06-12-2009, 08:17 AM   #7
Keith Seymore
Grounding issues can definitely result in weird behavior.
I clamped the bare end of the ground wire to the (metal) taillamp socket, and then ran the other end to a good clean bare spot on the frame.
You may have to do something a bit more tricky if your socket is plastic.
K
1979-1986
1986 - 2019
