Old 06-10-2009, 11:58 PM   #1
SnS C10
SnS C10's Avatar
I went from 4.75 to 5"
As some of you know i picked up these centerline dragstars the other day. well i call the local machine shop to get the rotors/axles/drums redrilled. they referred me to another machine shop who specializes in changing bolt pattern. what they did was move each hole 1/8" outward on a fadal cnc. then, hardened steel knurled inserts were pressed into each hole. presto now i have a 5x5.0 pattern. the black under the lug is the insert. it looks a lot better than i thought it would. he says they are just as strong as before they were put in. this is the only operation this machine shop does by the way. i know it may be skeptical but it looked very good to me and they are holding up to the rubber burning 454 that i have so far. just thought you guys may want to see how it would look. it cost me 60$ for 4 rims and took a day to finish.
SnS C10 is offline   Reply With Quote
Old 06-11-2009, 12:09 AM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: I went from 4.75 to 5"
they look good but a fresh coat of gloss black on the drums and suspension would look real good
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-11-2009, 07:49 AM   #3
Keith Seymore
Keith Seymore's Avatar
Why wasn't your bolt circle 5" originally?
I am thinking the production bolt pattern for these trucks (2wd) was "5 on 5".
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-11-2009, 07:55 AM   #4
63 & 64 Bowties
and a few others
K
that's what I was wondering too. I thought 4.75 was only cars and S-10's
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 06-11-2009, 08:44 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
His bolt pattern was 5x5. He found a deal on these wheels that were 5x4,75 and wanted to convert his truck to fit. The machine shop converted his wheels instead.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-11-2009, 09:03 AM   #6
Keith Seymore
Ah - I get it now. They changed the wheels, not the axle/rotor. Cool!
I'm probably a little slow on the uptake because we converted a '63 Tempest (from 4.5" to 4.75") but did the axles and rotors, so I was already thinking in that direction.
Thanks,
K
1979-1986
1986 - 2019
Old 06-11-2009, 09:40 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
That was his original idea that he expressed in another post. Fortunately he found a machine shop that made the conversion practical.
That 63 Tempest had an IRS didn't it?
Articles-
"Refining Sierra"
Old 06-11-2009, 10:02 AM   #8
Keith Seymore
Yes. They are a strange little car; front engine, trans is in the rear with a IRS swing axle, "rope" driveshaft.
K
1979-1986
1986 - 2019
