Old 06-11-2009, 09:10 AM   #1
colin_havens
colin_havens's Avatar
running brake lines for SD dropped crossmember or Porterbuilt Dropmember?
I am realizing that i will have to run new brake lines for my SD crossmember, as the factory ones I have are not only shot, but I dont see how they will fit. Does anyone have any pictures of how they ran their lines with the new crossmember for your brakes?The more detailed shots, the better! I have to run my airlines, and i want to run the the same time I run my brake lines for the cleanest install.
colin_havens is offline   Reply With Quote
Old 06-11-2009, 10:06 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: running brake lines for SD dropped crossmember or Porterbuilt Dropmember?
Id get some clamps from made for you products and start running your lines as long as they are clean and clamped to the frame they will look great..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-11-2009, 07:06 PM   #3
bentfab
bentfab's Avatar
I sell a pretty cool line clamp. Check out my site and look in the store. The line clamp is simple easy and clean.
bentfab is offline   Reply With Quote
