Old 06-11-2009, 01:04 PM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Taking 67-68 to disc and dropped spindles
When I started my build, I left on the "almost able to stop" drum setup on the front. I'm wanting to go disc in a few and get my drop out of my spindles instead of my JDM's with the 3" stepped spring pocket. There are some guys in my area that are parting out some truck cheap. Any reason why I couldn't get some 71-72 upper and lower A arms and put them on my '68??? Seems like all the dropped disc spindles are made for trucks already running disc.
prostreetC-10 is offline   Reply With Quote
Old 06-11-2009, 02:28 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Taking 67-68 to disc and dropped spindles
with any drop spindle from 60-70 you MUST run disc brakes on that spindle....sorry
John
1999 Toyota Tacoma 4x4
Old 06-11-2009, 02:43 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I'm not 100% sure what your question is pretaining to...
If you are asking if you could remove the 71-72 front suspension parts (spindles, disc brakes,...) and install them on your '68 and then have disc brakes... then yes you can do that.
If you are asking if you can swap the arms and still keep the drop you once had and run drums... I don't believe you can as the spindles are setup differently.
You can always contact ECE, CPP, or a board supporting vendor and pick up a disc brake conversion kit from one of them.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-11-2009, 02:50 PM   #4
prostreetC-10
My Carbon Footprint
let me clarify. I want disc with aftermarket drop. Most of the disc spindles wont work with 67-68 drum A arms. I thought the ball joints and tie rod ends were different. I guess you have answered my question anyway. As long as the 71-72 A arms will go on my '68....and I can then buy the spindles I will need with a drop.....then that's what I wanted to know. Thanks!
Old 06-11-2009, 03:40 PM   #5
oldblue1968chevy
i think your right it hard to udnerstand lol...
on my 68....
i had a 72 donor truck
i took the spindles rotors calipers soft lines pitmanarm to idler arm and everything inbetween and put it on my 68
what i put on that wanst used
new hardlines
balljoints
tierod ends
greasesweattears lol
but in the end discs are worth it....
i THINK you can buy drop spindles for your 68 that accept tierod ends and balljoints you already have and all you gotta do is mount a rotor and the rest of your brake components..
John
Old 06-11-2009, 04:08 PM   #6
my67chevytruck
Under Construction
my67chevytruck's Avatar
check out gmc paul. they sell a 63-70 drop spindle that will use the original ball joint etc. , but you have to switch to the disck brake upgrade.
http://gmcpauls.com/Suspension.htm
IIRC, I looked at the LMC catalog and the upper and lower control arms were the same part # for 67-72, just the balljoints/tie rods etc. are different
we did the complete front xmember swap and rear swap from a '72 to my son's '67, if you go this route get everything suspension/brake related and it will save you alot of time.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-12-2009, 10:14 AM   #7
Ford Assassin
Ford Assassin's Avatar
When I did my disc brake conversion on my '69 C10 I bought drop spindles that allowed me to retain my factory '69 upper/lower ball joints and tie rod ends. Figured that alone saved me $150+ the hassle of changing ball joints.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 06-12-2009, 07:16 PM   #8
Raguemoe
Junior Member
Raguemoe's Avatar
I upgraded to disc brakes on my 67. Got the kit from Classic performance Parts. Their kit uses stock arms, steering etc....
Raguemoe is offline   Reply With Quote
Old 06-12-2009, 08:07 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
All stock control arms,tie rod ends and ball joints on my 68 with 2 1/2 dropped spindles.Any BB vendor will probably have the kit.You will need to make sure your wheels are compatable with the disc.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-04-2009, 12:38 AM   #10
SIXT8LOU
SIXT8LOU's Avatar
my question is , i have a donor 72 1/2 ton, if i do a complete xmember swap with everything still intact, it should bolt right up to my 68?? do i have any other concerns i should be worried about?? i have a 72 power brake setup, M/C, proportioning valve,. i ve read that i might need to drill new holes in the 68 frame?
68 C/10 short bed
77 C/20 silverado long bed
05 GMC Duramax Crew
SIXT8LOU is offline   Reply With Quote
Old 07-04-2009, 09:58 AM   #11
oldblue1968chevy
idk on that you may have to drill a few holes.....dont member somebody else will post up
John
Old 07-04-2009, 10:07 AM   #12
prostreetC-10
My Carbon Footprint
I have stock 15x8 Corvette rallys up front with a stock 4" backspacing. I'm thinking those should clear since the corvette came with disc and I'm not planning on running Wilwood with 19" rotors! lol
Sound accurate?
Old 07-04-2009, 10:19 AM   #13
PanelDeland
Sounds right.I'm not 100% sure though.I am running the 73^ truck ralleys.If they are a 15" and were factory over disc's than I would think they would clear but then what do i know.
Old 07-04-2009, 10:53 AM   #14
prostreetC-10
My Carbon Footprint
You have over 8,000 posts!!!!!!
I hope not all of those are shooting from the hip!!!!! LOL
Old 07-04-2009, 11:01 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by SIXT8LOU View Post
.... i have a 72 power brake setup, M/C, proportioning valve,. i ve read that i might need to drill new holes in the 68 frame?
Here is your best solution. Bolt it up and enjoy...
BTW- You can use the same set up from 73-87 trucks, Burbs as well.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
