Old 06-11-2009, 05:39 PM   #1
leddzepp
Moderator
leddzepp's Avatar
How Do I wire a Factory Tach?
Can't find the info in FAQ. Got a tach harness, and no instructions came with it. It plugs into the back of the tach, has a pink wire (power) and a brown wire (coil) Where on the coil do I connect the brown wire? Pos side or Neg side? DO I need a ground wire also? Thanks. This is for non-HEI, factory ignition...otherwise the wire just goes to "tach" on the cap!
leddzepp is offline   Reply With Quote
Old 06-11-2009, 05:48 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: How Do I wire a Factory Tach?
neg post on the coil.
The tach grounds through the inst panel
Old 06-11-2009, 05:50 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Thanks Andy, I'm going back out to hook it up now.
