ATemperature sending unit with Vortec heads
I bought a sending unit without thinking, brought it home and the threads that go into the block are wayyyyy to big. I ordered one for a 97 tahoe (my head came off of) an dit has a different connector for the wire hook-up. Will these work on the dash guage or will I need to buy aftermarket to get to work. I should probably do that anyway to see what my reading truly is.
Re: ATemperature sending unit with Vortec heads
I never trusted those ol gages. Just put in an aftermarket one it comes all the adapter and so forth.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: Mar 2005
i installed my temp. sending unit in the intake. not the most desireable or accurate place to put it,but it works.
![]() Join Date: Dec 2008
I can turn down and re-thread the stock style sending unit to 3/8 pipe. This will allow it to fit into the vortec heads. Cost is 25.00. This includes a new sending unit and shipping. PM me if you have more questions.I sold two of these to board members, but I can't remember who they are. Maybe they will chime in.
Same thing rigtht.. as long as it works. I will still upgrade the temp guage. If this is the only way.. I will be in touch with you. I have a swapmeet in my area. I'll see if anyone has one there.. if not, we'll be in touch.
Thank you. |
I was able to pick up locally for $10. Works perfect.
![]() Join Date: May 2005
Part # please, and where ya got it would be great.
I see you're a little ways away.. but mine was bought at tops auto in anaheim ca. What you could do is call them and ask for their distributors numbers. Call them, and see if they distribute to an auto parts store in your area. If not, at least you know you've got at least 3 places where they could be ordered if you needed one bad enough.
If you do decide to call Tops, ask for Kevin. He's sharpe and up on street roddin etc. Now how accurate these guages are I don't know. I do notice though that at times, it runs a tad hotter than the old motor. |
Since no one seems to have a correct vortec sender number for our trucks gauges, I rigged this up to get by until I find the correct 3/8" sender. Yes, I need to clean up that connection...
![]() ![]() ![]() Parts: Napa TS6469SB Temp Switch $7.33 Home Depot Watts A-815 Pipe Reducing Coupling 1/2" x 3/8" FIP $4.59 Home Depot Watts A-785 Brass Pipe Nipple 3/8" x 3/8" MIP $1.91 Total cost: $13.83 It isn't ideal, because the length of the sender housing goes almost to the pipe nipple. I used teflon tape to make it tighten sooner and give it some room. The waterflow around the housing won't be very good since it's inside the coupling. The good news is that it works and since our temp gauge is just a "relative" temperature reading, it works just fine. Just remember where it sits in high temp traffic situations... Anyway, if anyone ever gets a part number for the vortec sender, it would be nice to post here.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
newly minted old timer
i used the stock sensor, and just went to a pluming store and bought a step down coupler and a nipple.. works great
![]() we talked about it in this thread http://67-72chevytrucks.com/vboard/s...t=sending+unit
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban Last edited by mtdave2; 09-20-2009 at 09:02 PM. |
Same thing, just pipe instead of brass.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
#13 |
Too Dumb To Know Better
I used the stock sender in my LT1 and used a resistor to adjust the ohms to match the old gauge. Works great.
#14 |
Any details?
#15 | |
![]() Join Date: Jul 2004
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
