Old 06-12-2009, 12:26 PM   #1
vpippen
Thumbs up frame shorting Ques.?
Okay everone. woke up this morning and had an idea! had to get coffee in me first but anywayz, i have 2 long beds one a 70 chev and one a 72 GMC . im thinking that i have 2 frames and i could shorten one to a short wheel base (always wanted one). but my question is can i use the trailing arms of my long bed after i shorten the frame? iknow the procedure on shorting the frame but i don't know if i can use these trailing arms . any help will of course help, and also i would need a one piece drive shaft right.? any info would be great
vpippen is offline   Reply With Quote
Old 06-12-2009, 01:05 PM   #2
90\87Formula
90\87Formula's Avatar
Re: frame shorting Ques.?
You shouldn't even have to touch the trailing arms. The frame cuts are made in front of the trailing arm crossmember. Check over in the FAQ section, I believe there is at least one post about shortening frames. Lots of info there.
Here's the link.: http://www.67-72chevytrucks.com/vboa...hlight=shorten
Robert
Member 1532
90\87Formula is offline   Reply With Quote
Old 06-12-2009, 09:13 PM   #3
vpippen
thanks alot got it . i found a thread with all the mesurements and all what to do , thats the only thing iwas curious about. thanks
Old 06-12-2009, 09:16 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Trailing arms are the same length, long and short wheel base. And as stated already, the major cut is ahead of them. No issues at all.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
