68 air cleaner, exh manifolds, alt assy, 70 tire carrier
2 barrel air cleaner
$25 ![]() ![]() Ram horn manifolds, need cleaning and painting, I can blast and paint for $25 extra, threads/studs in good shape. $50 ![]() ![]() ![]() Alternator and brackets $50 ![]() Spare tire carrier $25 - SOLD ![]() ![]()
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! Last edited by puppy; 12-21-2009 at 10:57 AM. |
Re: 68 air cleaner, exh manifolds, alt assy, 70 tire carrier
Tire carrier - $35 to your door.
Manifolds - $25 + shipping.
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! |
![]() Join Date: May 2006
Could you get the numbers off of the alt. for me?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
No problem. I will try to get those this afternoon.
110069337 is the number I found.
BTW, I have always wondered where you find the info to decode these alternators. Could you share that info?
Make for a good present to yourself.
Chemist under the hood...
Do you still have the alternator brackets? I need some for a 283 with no holes in head or block. Do you think those will work in my '67 (driver's side mount)?
I don't need that alternator if you are willing to sell separately. Thanks!
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] Last edited by Legolas894; 12-14-2009 at 12:03 AM. Reason: Added extra information. |
I can't remember how these mounted. Maybe someone will chime in and clear this up.
I don't see why it wouldn't.
I took it off of a 70 SWB.
would the tire carrier work for 16 inch rim?
and are the ram horns for a 350?
1972 Cheyenne super 20 original |
im really interested in the tire carrier but i dont know how to do a pm or anything so could you walk me through it. if it fits a 16 ill take it
#13 |
give me a call when you can 6026391981 thanks
#14 |
Called and left message.
#15 | |
![]() Join Date: Aug 2008
![]() ![]() With the alternator secured. The other arm attaches at the WP. I used tall valve covers and there is not much clearance. ![]() ![]() Hope this helps |
#16 |
Thanks!
#17 |
Soooo close. Your picture shows a boss on the ram's horn exhaust manifold. Does the bolt through the bracket go through the bottom of the alternator and into the boss? Or does the bracket just have an attachment to the water pump bolt and the alternator bolt? I don't have the boss on the ram's horns.
Thanks!!!
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
#18 | |
#19 |
Man!-It's hard to find the what the stock bracket looked like. No holes in head, no holes in block and no holes in exhaust manifold. What did it bolt to?
#20 |
Tire carrier is SOLD.
#21 |
Puppy- don't mean to highjack this thread...
Was it originally mounted low- like this? http://67-72chevytrucks.com/vboard/s...d.php?t=341008 |
#22 |
I love the tech. Carry on!
#23 | |
#24 |
#25 | |
Really, I just want it back to stock. I had the water pump pulley break apart and then I had a bolt on the alternator break off in the block (I got it out though). So, I found another pulley and put the whole thing back together but I'm worried that it is not exactly right. Thanks for all your posts. My other option is to get a manifold with the boss on it. SORRY AGAIN TO PUPPY!! ![]()
